Power: Suspend on Raspberry Pi 4
Any experience on a Raspberry Pi 4 with Suspend to be working? Thanks.
As far as I know, RPi doesn’t have any sleep mode (aka suspension to ram).
Saves a lot of time searching for it…
Any ideas, if Screen Blank is supposed to work? At least, I can be selected but seems to have no effect.
Screen Blank works on KDE Plasma. I don’t know about other DEs or WMs.
@sradjoker could tell if it works on Mate.
Pudge
RPi4B | EnOS ARM | Cinnamon
I can use the power management in the system settings and set the screen to go blank when inactive for a certain amount of time. It does seem to work.
Screenshot from 2022-10-10 18-46-35
I am under Gnome Wayland on HDMI and it does not work. However, it might bei a DVI issue i.e. need to get an adapter.
