I need either Topaz of DxO Photolab. I admire your attempts at explaining how some things are good enough - and indeed, some are. I even use Darktable on Windows (where it runs worse than in Linux). But if you’re shooting wildlife with long lenses with £8000 of kit, and not £19000 of kit (and actually even then), then denoising IS a part of the process, and no, in many cases, we can’t explain it away by saying it looks good.
Hmm… last time I tried, Wine failed pretty bad with Topaz (about two years ago). I’m currently using a VM, but will give Wine another look with Topaz. If it works with Wine, that’s one less headache
One thing to keep in mind - don’t use system wine, because update can certainly break some things, it rolls incredibly fast, once you’ve found a good version for specific software - keep it.
More on how to use portable wine you can find here
With this setup, I’m getting 5K all through (i.e. login window, and then my session). I wonder where it’s getting the settings to do 5K from when the /etc/X11/xorg.conf says to use only one monitor.
Topaz Denoise is working nicely with your override. I’m trying to get PhotoAI running under wine too. But the installer flat out crashes when starting. I was wondering if you managed to get that running somehow.
So, trial demo installer works out of the box (tested with wine 6.17 staging) and gives this error:
Changed to Windows 10 in winecfg for that wineprefix
After then i’ve got that warning which restricts proceeding…
So i guess you’re doomed if your CPU doesn’t support AVX instructions…
However that being said - my CPU clearly supports it, yet still i have this stupid error.
Which means that installer is utterly broken crap, i suggest to wait for some portable version or make your own, if you really need this program.
