While updating graphviz as part of a system update, I saw the following in pacman’s output:
Warning: Could not load "/usr/lib/graphviz/libgvplugin_gtk.so.6" - It was found, so perhaps one of its dependents was not. Try ldd.
So I did:
ldd /usr/lib/graphviz/libgvplugin_gdk.so.6
linux-vdso.so.1 (0x00007ffcab920000)
libgvc.so.6 => /usr/lib/libgvc.so.6 (0x00007fdbf194b000)
libgdk-x11-2.0.so.0 => not found
(snipped) and so installed gtk2 which fixed that. GTK2 is listed as an optional dependency when doing pacman -Qi graphviz
Depends On : libltdl gd librsvg libxaw ghostscript pango gts gsfonts libnsl libpng
Optional Deps : mono: sharp bindings
guile: guile bindings [installed]
lua: lua bindings [installed]
ocaml: ocaml bindings
perl: perl bindings [installed]
python: python bindings [installed]
r: r bindings
tcl: tcl bindings [installed]
qt5-base: gvedit [installed]
gtk2: gtk output plugin [installed]
xterm: vimdot [installed]
Required By : vala
Should it be a non-optional dependency or was there another way to resolve this?
System information, just in case it’s relevant.
