Possible problem with latest mesa update?
I run Arch and just experienced a possible issue with the latest Mesa update, version 1:24.0.1-1. I run
  Host: eznix-optiplex9010 Kernel: 6.6.17-1-lts arch: x86_64 bits: 64
  Desktop: Xfce v: 4.18.1 Distro: Arch Linux
  Type: Desktop System: Dell product: OptiPlex 9010 v: 01
    serial: <superuser required>
  Mobo: Dell model: 00F82W v: A00 serial: <superuser required> BIOS: Dell
    v: A13 date: 03/27/2013
  Info: quad core Intel Core i5-3570 [MCP] speed (MHz): avg: 2175
    min/max: 1600/3800
  Device-1: AMD Oland XT [Radeon HD 8670 / R5 340X OEM R7 250/350/350X OEM]
    driver: radeon v: kernel
  Device-2: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
    type: USB
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4 driver: X:
    loaded: radeon unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: radeon
    resolution: 1920x1080~60Hz
 API: OpenGL v: 4.5 vendor: amd mesa v: 23.3.5-arch1.1 glx-v: 1.4
    direct-render: yes renderer: OLAND (radeonsi LLVM 16.0.6 DRM 2.50
    6.6.17-1-lts)
  Device-1: Intel 82579LM Gigabit Network driver: e1000e
  Local Storage: total: 931.51 GiB used: 153.37 GiB (16.5%)
  Memory: total: 16 GiB available: 15.58 GiB used: 1.56 GiB (10.0%)
  Processes: 194 Uptime: 13m Shell: Bash inxi: 3.3.33
With Xfce as the desktop and Sddm as the display manager. I was just curious if others are experiencing issues with today’s Mesa update. I downgraded Mesa and listed it to ignore updates for that package and the system updates and runs well for the moment. Thanks.
Possibly related:
https://bbs.archlinux.org/viewtopic.php?id=292882
please read the topic before posting it as reference. The user there had libdrm from outside the repo and therefore ran into self-made problems.
would you mind telling us what your actual issue was?
i am running mesa 24 since rc2 and no issues here, already updated to 24.0.1 Thursday morning.
This was back in 2022. I don’t think it’s the same scenario.
I posted the link to the forum because: 1) the OP didn’t specify what the exact issue was; 2) the problem the user had in the Arch forum was specific to Mesa 1:24; 3) the steps and suggestions proposed by the users in the Arch forum may also help the OP diagnose his specific problem.
I also mentioned “possibly-related.” Not sure what part about that is unclear.
I also have the latest updates and no issues that i notice on Plasma.
2022? I thought the post in the Arch forum was made a few days ago when the mesa package in question was still in the testing repo?
Looks to be posted on 2.15.24 to me. I’m lost too.
Isn’t it this?
You are looking at the date the user joined, not the post date.
that just tells that glxinfo is missing and that inxi can’t query the information due to that. Every EndeavourOS install shows that by default if the user does not install mesa-utils
I thought that was part of mesa-utils
yes, but that was not installed by default. the only packages requiring that on my system are Required By : kinfocenter lutris - so it might actually be installed on new installs after the switch to Plasma as default DE, but only if it was installed with that.
inxi itself only lists it as optional dependency.
Sorry you right I had two different pages open in the browser looking at stuff so my bad! :man_facepalming:
Probably… :thinking:
It appears that the latest Mesa is causing sddm to dump core:
Feb 17 16:40:46 eznix-optiplex9010 kernel: sddm-greet:gl0[947]: segfault at 40 ip 000078001a2cd545 sp 000077ffe0f2f8f0 error 4 in radeonsi_dri.so[780019c14000+14dd000] likely on CPU 1 (core 1, socket 0)
Feb 17 16:40:46 eznix-optiplex9010 kernel: Code: ec 00 00 00 31 db 49 89 e5 eb 3b 66 2e 0f 1f 84 00 00 00 00 00 4d 03 77 38 49 8b 36 48 85 f6 74 0e f0 83 2e 01 75 08 4c 89 e7 <41> ff 54 24 40 49 c7 06 00 00 00 00 41 8b 57 30 48 83 c3 01 39 d3
Feb 17 16:40:46 eznix-optiplex9010 systemd[1]: Created slice Slice /system/systemd-coredump.
Feb 17 16:40:46 eznix-optiplex9010 systemd[1]: Started Process Core Dump (PID 953/UID 0).
Feb 17 16:40:46 eznix-optiplex9010 systemd-coredump[954]: Process 924 (sddm-greeter) of user 967 dumped core.
                                                          Stack trace of thread 947:
                                                          #0  0x000078001a2cd545 n/a (radeonsi_dri.so + 0x6cd545)
                                                          #1  0x000078001a2cd711 n/a (radeonsi_dri.so + 0x6cd711)
                                                          #2  0x000078001a755396 n/a (radeonsi_dri.so + 0xb55396)
                                                          #3  0x000078001a755539 n/a (radeonsi_dri.so + 0xb55539)
                                                          #4  0x000078001a2e4e7b n/a (radeonsi_dri.so + 0x6e4e7b)
                                                          #5  0x000078001a415803 n/a (radeonsi_dri.so + 0x815803)
                                                          #6  0x000078001a415afc n/a (radeonsi_dri.so + 0x815afc)
                                                          #7  0x0000780019e39278 n/a (radeonsi_dri.so + 0x239278)
                                                          #8  0x0000780019e39fd9 n/a (radeonsi_dri.so + 0x239fd9)
                                                          #9  0x0000780019e3a222 n/a (radeonsi_dri.so + 0x23a222)
                                                          #10 0x0000780019c9cf29 n/a (radeonsi_dri.so + 0x9cf29)
                                                          #11 0x0000780019ca2f52 n/a (radeonsi_dri.so + 0xa2f52)
                                                          #12 0x0000780019c8692d n/a (radeonsi_dri.so + 0x8692d)
                                                          #13 0x0000780019c9e83c n/a (radeonsi_dri.so + 0x9e83c)
                                                          #14 0x0000780025aa955a n/a (libc.so.6 + 0x8b55a)
                                                          #15 0x0000780025b26a3c n/a (libc.so.6 + 0x108a3c)
                                                          Stack trace of thread 926:
                                                          #0  0x0000780025b190bf __poll (libc.so.6 + 0xfb0bf)
                                                          #1  0x0000780027a6e20b n/a (libxcb.so.1 + 0xd20b)
                                                          #2  0x0000780027a6ff3d xcb_wait_for_event (libxcb.so.1 + 0xef3d)
                                                          #3  0x0000780021d2d032 n/a (libQt5XcbQpa.so.5 + 0x5d032)
                                                          #4  0x00007800260eb79a n/a (libQt5Core.so.5 + 0xeb79a)
                                                          #5  0x0000780025aa955a n/a (libc.so.6 + 0x8b55a)
                                                          #6  0x0000780025b26a3c n/a (libc.so.6 + 0x108a3c)
                                                          Stack trace of thread 924:
                                                          #1  0x000078002505e2f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                          #2  0x0000780024ffe162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                          #3  0x00007800262e2d0c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2e2d0c)
                                                          #4  0x0000780026292c04 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x292c04)
                                                          #5  0x00007800262940a3 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2940a3)
                                                          #6  0x000056061c9a25b5 n/a (sddm-greeter + 0x125b5)
                                                          #7  0x0000780025a43cd0 n/a (libc.so.6 + 0x25cd0)
                                                          #8  0x0000780025a43d8a __libc_start_main (libc.so.6 + 0x25d8a)
                                                          #9  0x000056061c9a5655 n/a (sddm-greeter + 0x15655)
                                                          Stack trace of thread 934:
                                                          #0  0x0000780025aa5ebe n/a (libc.so.6 + 0x87ebe)
                                                          #1  0x0000780025aa8750 pthread_cond_wait (libc.so.6 + 0x8a750)
                                                          #2  0x0000780019c8686c n/a (radeonsi_dri.so + 0x8686c)
                                                          #3  0x0000780019c9e83c n/a (radeonsi_dri.so + 0x9e83c)
                                                          #4  0x0000780025aa955a n/a (libc.so.6 + 0x8b55a)
                                                          #5  0x0000780025b26a3c n/a (libc.so.6 + 0x108a3c)
                                                          Stack trace of thread 940:
                                                          #5  0x00007800260ef576 _ZN7QThread4execEv (libQt5Core.so.5 + 0xef576)
                                                          #6  0x00007800270c5a20 n/a (libQt5Qml.so.5 + 0x2c5a20)
                                                          #7  0x00007800260eb79a n/a (libQt5Core.so.5 + 0xeb79a)
                                                          #8  0x0000780025aa955a n/a (libc.so.6 + 0x8b55a)
                                                          #9  0x0000780025b26a3c n/a (libc.so.6 + 0x108a3c)
                                                          Stack trace of thread 928:
                                                          #6  0x0000780021c67a9a n/a (libQt5DBus.so.5 + 0x17a9a)
                                                          Stack trace of thread 943:
                                                          #1  0x0000780025aa8a65 pthread_cond_timedwait (libc.so.6 + 0x8aa65)
                                                          #2  0x00007800260f34b4 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xf34b4)
                                                          #3  0x00007800260f05ea n/a (libQt5Core.so.5 + 0xf05ea)
                                                          Stack trace of thread 942:
                                                          Stack trace of thread 946:
                                                          Stack trace of thread 931:
                                                          Stack trace of thread 932:
                                                          Stack trace of thread 949:
                                                          Stack trace of thread 933:
                                                          Stack trace of thread 950:
                                                          Stack trace of thread 936:
                                                          Stack trace of thread 944:
                                                          Stack trace of thread 941:
                                                          Stack trace of thread 945:
                                                          Stack trace of thread 935:
                                                          Stack trace of thread 951:
                                                          Stack trace of thread 948:
                                                          #0  0x0000780025b2488d syscall (libc.so.6 + 0x10688d)
                                                          #1  0x0000780019c8557e n/a (radeonsi_dri.so + 0x8557e)
                                                          #2  0x0000780019cb150b n/a (radeonsi_dri.so + 0xb150b)
                                                          #3  0x0000780019c3cd70 n/a (radeonsi_dri.so + 0x3cd70)
                                                          #4  0x00007800209de90f n/a (libGLX_mesa.so.0 + 0x5090f)
                                                          #5  0x00007800209ca7bb n/a (libGLX_mesa.so.0 + 0x3c7bb)
                                                          #6  0x00007800212c1684 n/a (libqxcb-glx-integration.so + 0x8684)
                                                          #7  0x00007800275f8afc n/a (libQt5Quick.so.5 + 0x1f8afc)
                                                          #8  0x00007800275fd004 n/a (libQt5Quick.so.5 + 0x1fd004)
                                                          #9  0x00007800260eb79a n/a (libQt5Core.so.5 + 0xeb79a)
                                                          #10 0x0000780025aa955a n/a (libc.so.6 + 0x8b55a)
                                                          #11 0x0000780025b26a3c n/a (libc.so.6 + 0x108a3c)
                                                          ELF object binary architecture: AMD x86-64
Feb 17 16:40:46 eznix-optiplex9010 systemd[1]: systemd-coredump@0-953-0.service: Deactivated successfully.
Feb 17 16:40:46 eznix-optiplex9010 sddm-helper[910]: [PAM] Closing session
Feb 17 16:40:46 eznix-optiplex9010 sddm-helper[910]: pam_unix(sddm-greeter:session): session closed for user sddm
Feb 17 16:40:46 eznix-optiplex9010 sddm-helper[910]: [PAM] Ended.
Feb 17 16:40:46 eznix-optiplex9010 sddm[754]: Auth: sddm-helper exited with 11
Feb 17 16:40:46 eznix-optiplex9010 systemd[1]: session-c1.scope: Deactivated successfully.
Feb 17 16:40:46 eznix-optiplex9010 sddm[754]: Greeter stopped. SDDM::Auth::HelperExitStatus(11)
Feb 17 16:40:46 eznix-optiplex9010 systemd-logind[671]: Session c1 logged out. Waiting for processes to exit.
I can post more of the journal output if need be. Just let me know. Thanks. Btw, I installed mesa-utils so glxinfo should be present now.
Seems like I am not the only person with this type of issue:
The kind folks over at the Arch forums got me up to speed in backtracing!
Same. System run, but freezing (plasma) desktop, not moving mouse.
Neccesary arch-chroot downgrade mesa.
$ inxi -SG
  Host: eco Kernel: 6.7.5-arch1-1 arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 5.27.10 Distro: EndeavourOS
  Device-1: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E] driver: radeon
    v: kernel
    loaded: radeon unloaded: modesetting dri: radeonsi gpu: radeon
  API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
    platforms: gbm,x11,surfaceless,device
  API: OpenGL v: 4.5 vendor: amd mesa v: 23.3.5-arch1.1 renderer: VERDE
    (radeonsi LLVM 16.0.6 DRM 2.50 6.7.5-arch1-1)
I managed to downgrade mesa by ctl-alt-f4 to a TTY and also ignorepkg = mesa in pacman.conf. Just hold tight on the previous version of mesa until its fixed. Good luck. :slight_smile:
Ok then I am not experiencing this issue because I am starting sddm in wayland mode on all my machines and also use plasma wayland session xD
