Hi everyone. I am in EnOS i3 edition. I am facing an issue with bluetooth. I have installed bluez, bluez-utils. I use a bluethooth speaker with my laptop. Everything is fine when the speaker is just next to laptop. But if the speaker is away 1 or 2 meter it will lost signal. And even if it connected it will just don’t output any sound.
Searched for a while couldn’t find any solution in google. So I decided to upload here.
Is this a new or old install? Pipewire or pulse?
I have had a WAYYYYYY better experience with pipewire than I did on pulse. It sounds and works fathoms better for me.
tbg
February 19, 2022, 4:03pm
#4
Hey, this is Endeavour, shouldn’t that be measured in light years?
I thought the Endeavour was a ship? Isn’t the logo the sails?? (I still don’t quite get the connection to space travel)
Hi there
Here is the output
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 04f2:b56c Chicony Electronics Co., Ltd HP TrueVision HD
Bus 001 Device 004: ID 0bda:b008 Realtek Semiconductor Corp. Bluetooth Radio
Bus 001 Device 003: ID 248a:8514 Maxxter Wireless Receiver
Bus 001 Device 002: ID 0e8f:0022 GreenAsia Inc. multimedia keyboard controller
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation Skylake GT2 [HD Graphics 520] (rev 07)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 08)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile] (rev 83)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter
The default is pipewire and I loved it.
tbg
February 19, 2022, 4:29pm
#8
This is an old post, but changing the ant select setting may be worth trying. This is a very problem prone wifi/bt combo chip.
Also be sure your bios is up to date.
I got the issue but don’t know how to exactly fix this. I haven’t used modprobe before.
Edit: I tried the soultion and put 1 and 2 in ant_sel but didn’t work.
Edit: It’s weird. When I use wifi and bluetooth both then range of bluetooth is really good. But if i turn wifi off and use ethernet bluethooth is dead low.
tbg
February 19, 2022, 5:12pm
#10
Try:
sudo modprobe -r rtl8723be; sleep 2; sudo modprobe rtl8723be ant_sel=2
Or try:
sudo modprobe -r rtl8723be; sleep 2; sudo modprobe rtl8723be ant_sel=1
A reboot will revert the changes.
tbg
February 19, 2022, 5:18pm
#12
You’re welcome, glad that helped.
system
closed
February 21, 2022, 5:19pm
#13
