Hi,
I am just playing with the bars on my i3.
Finally I got how to edit i3block but it is still looks older than polybar.
Polybar has some “modern” look.
So I wanted to use polybar instead of blocks.
But but , I got some weird errors.
What I did, cloned polybar setup from bspwm. and added in my i3 config this :
Polybar
exec_always --no-startup-id ~/.config/polybar/launch.sh
As you can see here some errors.
Here is my config of i3 :
# iconic font icon search: https://fontawesome.com/v4.7/cheatsheet/
# --> to update this run the following command (will backup existing setup file)
# wget --backups=1 https://raw.githubusercontent.com/endeavouros-team/endeavouros-i3wm-setup/main/.config/i3/config -P ~/.config/i3/
# Endeavouros-i3 config file
# Source for complete framework of our i3 config and theming here: https://github.com/endeavouros-team/endeavouros-i3wm-setup
# EndeavourOS wiki holds some Information also: https://discovery.endeavouros.com/window-tiling-managers/i3-wm/
# Please see http://i3wm.org/docs/userguide.html for the official i3 reference!
# config starts here: #
# Font for window titles. Will also be used by the bar unless a different font
# is used in the bar {} block below.
# This font is widely installed, provides lots of unicode glyphs, right-to-left
# text rendering and scalability on retina/hidpi displays (thanks to pango).
font pango:Noto Sans Regular 10
# set the mod key to the winkey:
set $mod Mod4
# workspace layout: #
# default i3 tiling mode:
workspace_layout default
# i3 stacking layout:
# Each window will be fullscreen and tabbed top to bottom.
#workspace_layout stacking
# i3 tabbed layout:
# Each new window will open fullscreen as a tab (left to right)
#workspace_layout tabbed
# extra options for windows: #
#border indicator on windows:
new_window pixel 1
# thin borders
# hide_edge_borders both
# Set inner/outer gaps
gaps inner 6
gaps outer 3
# Use Mouse+$mod to drag floating windows to their wanted position
floating_modifier $mod
# switch to workspace
bindsym $mod+1 workspace $ws1
bindsym $mod+2 workspace $ws2
bindsym $mod+3 workspace $ws3
bindsym $mod+4 workspace $ws4
bindsym $mod+5 workspace $ws5
bindsym $mod+6 workspace $ws6
bindsym $mod+7 workspace $ws7
bindsym $mod+8 workspace $ws8
bindsym $mod+9 workspace $ws9
bindsym $mod+0 workspace $ws10
# move focused container to workspace
bindsym $mod+Shift+1 move container to workspace $ws1
bindsym $mod+Shift+2 move container to workspace $ws2
bindsym $mod+Shift+3 move container to workspace $ws3
bindsym $mod+Shift+4 move container to workspace $ws4
bindsym $mod+Shift+5 move container to workspace $ws5
bindsym $mod+Shift+6 move container to workspace $ws6
bindsym $mod+Shift+7 move container to workspace $ws7
bindsym $mod+Shift+8 move container to workspace $ws8
bindsym $mod+Shift+9 move container to workspace $ws9
bindsym $mod+Shift+0 move container to workspace $ws10
# resize window (you can also use the mouse for that):
#mode "resize" {
# These bindings trigger as soon as you enter the resize mode
# Pressing left will shrink the window’s width.
# Pressing right will grow the window’s width.
# Pressing up will shrink the window’s height.
# Pressing down will grow the window’s height.
# bindsym j resize shrink width 10 px or 10 ppt
# bindsym k resize grow height 10 px or 10 ppt
# bindsym l resize shrink height 10 px or 10 ppt
# bindsym ntilde resize grow width 10 px or 10 ppt
# same bindings, but for the arrow keys
# bindsym Left resize shrink width 10 px or 10 ppt
# bindsym Down resize grow height 10 px or 10 ppt
# bindsym Up resize shrink height 10 px or 10 ppt
# bindsym Right resize grow width 10 px or 10 ppt
# back to normal: Enter or Escape
# bindsym Return mode "default"
# bindsym Escape mode "default"
#bindsym $mod+r mode "resize"
# keybindings for different actions: #
# start a terminal
bindsym $mod+Return exec xfce4-terminal
# kill focused window
bindsym $mod+c kill
# exit-menu
bindsym $mod+Shift+e exec ~/.config/i3/scripts/powermenu
# Lock the system
# lock with a picture:
#bindsym $mod+l exec i3lock -i ~/.config/i3/i3-lock-screen.png -p default|win -t
# lock by blurring the screen:
bindsym $mod+l exec ~/.config/i3/scripts/blur-lock.sh
# reload the configuration file
bindsym $mod+Shift+c reload
# restart i3 inplace (preserves your layout/session, can be used to upgrade i3)
bindsym $mod+Shift+r restart
# keybinding list in editor:
bindsym $mod+F1 exec xed ~/.config/i3/keybindings
# Backlight control
bindsym XF86MonBrightnessDown exec brightnessctl set 5%-
bindsym XF86MonBrightnessUp exec brightnessctl set +5%
# change focus
bindsym $mod+j focus left
bindsym $mod+k focus down
bindsym $mod+b focus up
bindsym $mod+o focus right
# alternatively, you can use the cursor keys:
bindsym $mod+Left focus left
bindsym $mod+Down focus down
bindsym $mod+Up focus up
bindsym $mod+Right focus right
# move focused window
bindsym $mod+Shift+j move left
bindsym $mod+Shift+k move down
bindsym $mod+Shift+b move up
bindsym $mod+Shift+o move right
bindsym $mod+Shift+Left move left
bindsym $mod+Shift+Down move down
bindsym $mod+Shift+Up move up
bindsym $mod+Shift+Right move right
# split in horizontal orientation
bindsym $mod+h split h
# split in vertical orientation
bindsym $mod+v split v
# enter fullscreen mode for the focused container
bindsym $mod+f fullscreen toggle
# change container layout (stacked, tabbed, toggle split)
bindsym $mod+s layout stacking
bindsym $mod+g layout tabbed
bindsym $mod+e layout toggle split
# toggle tiling / floating
bindsym $mod+Shift+space floating toggle
# change focus between tiling / floating windows
bindsym $mod+space focus mode_toggle
# focus the parent container
bindsym $mod+a focus parent
# open new empty workspace
bindsym $mod+Shift+n exec ~/.config/i3/scripts/empty_workspace.sh
## Multimedia Keys
# volume
bindsym XF86AudioRaiseVolume exec amixer -D pulse sset Master 5%+ && pkill -RTMIN+1 i3blocks
bindsym XF86AudioLowerVolume exec amixer -D pulse sset Master 5%- && pkill -RTMIN+1 i3blocks
# Pulse Audio controls
#volume up
#bindsym XF86AudioRaiseVolume exec pamixer -i 5 --allow-boost && dunstify -h string:x-dunst-stack-tag:volume volume: $(pamixer --get-volume)%
#volume down
#bindsym XF86AudioLowerVolume exec pamixer -d 5 --allow-boost && dunstify -h string:x-dunst-stack-tag:volume volume: $(pamixer --get-volume)%
#mute
#bindsym XF86AudioMute exec pamixer -t && dunstify -h string:x-dunst-stack-tag:mute mute: $(pamixer --get-mute)!
# gradular volume control
bindsym $mod+XF86AudioRaiseVolume exec amixer -D pulse sset Master 1%+ && pkill -RTMIN+1 i3blocks
bindsym $mod+XF86AudioLowerVolume exec amixer -D pulse sset Master 1%- && pkill -RTMIN+1 i3blocks
# mute
#bindsym XF86AudioMute exec amixer sset Master toggle && killall -USR1 i3blocks
#mute
bindsym XF86AudioMute exec pamixer -t && notify-send "mute: $(pamixer --get-mute)"
bindsym XF86AudioPlay exec playerctl play
bindsym XF86AudioPause exec playerctl pause
bindsym XF86AudioNext exec playerctl next
bindsym XF86AudioPrev exec playerctl previous
# Redirect sound to headphones
bindsym $mod+p exec /usr/local/bin/switch-audio-port
## App shortcuts
bindsym $mod+w exec /usr/bin/firefox
bindsym $mod+n exec /usr/bin/thunar
bindsym Print exec "scrot ~/%Y-%m-%d-%T-screenshot.png"
# configuration for workspace behaviour: #
# Define names for default workspaces for which we configure key bindings later on.
# We use variables to avoid repeating the names in multiple places.
set $ws1 "1:"
set $ws2 "2:"
set $ws3 "3:"
set $ws4 "4:"
set $ws5 "5:"
set $ws6 "6"
set $ws7 "7"
set $ws8 "8"
set $ws9 "9"
set $ws10 "10"
# use workspaces on different displays:
# where you have to replace VGA-0/HDMI-0 with the names for your displays
# you can get from xrandr command
#workspace $ws1 output VGA-0
#workspace $ws2 output VGA-0
#workspace $ws3 output HDMI-0
#workspace $ws4 output HDMI-0
#workspace $ws5 output HDMI-0
# bind program to workspace and focus to them on startup:
assign [class="Xfce4-terminal"] $ws1
assign [class="(?i)firefox"] $ws2
assign [class="Thunar"] $ws3
assign [class="Thunderbird"] $ws4
assign [class="TelegramDesktop"] $ws5
# automatic set focus new window if it opens on another workspace then the current:
for_window [class=Xfce4-terminal] focus
for_window [class=(?i)firefox] focus
for_window [class=Thunar] focus
for_window [class=Thunderbird] focus
for_window [class=TelegramDesktop] focus
# autostart applications/services on login: #
#get auth work with polkit-gnome
exec --no-startup-id /usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1
# dex execute .desktop files
# keep in mind that it can cause issues
# when second to i3 a DE is installed or mixed usage of i3 + xfce4 or GNOME
# in this cases better disable dex and use manual starting apps using xdg/autostart
exec --no-startup-id dex -a -s /etc/xdg/autostart/:~/.config/autostart/
# num lock activated
#exec --no-startup-id numlockx on
# start conky:
#exec_always --no-startup-id conky
Polybar
# start a script to setup displays
# uncomment the next line, use arandr to setup displays and save the file as monitor:
exec --no-startup-id ~/.screenlayout/monitor.sh
# start blueberry app for managing bluetooth devices from tray:
exec --no-startup-id blueberry-tray
#transparency
#exec --no-startup-id xcompmgr -c -C -t-5 -l-5 -r4.2 -o.55 &
exec --no-startup-id picom -CGb
#networkmanager-applet
exec --no-startup-id nm-applet
# set wallpaper
exec --no-startup-id nitrogen --restore
#exec --no-startup-id feh --bg-fill /usr/share/endeavouros/backgrounds/endeavouros_i3.png
#set powersavings for display:
exec --no-startup-id xset s 480 dpms 600 600 600
# Desktop notifications
exec --no-startup-id dbus-launch dunst --config ~/.config/dunst/dunstrc
# Autostart apps as you like
#exec --no-startup-id sleep 2 && xfce4-terminal
#exec --no-startup-id sleep 7 && firefox https://github.com/endeavouros-team/endeavouros-i3wm-setup/blob/main/force-knowledge.md
#exec --no-startup-id sleep 3 && thunar
# set floating (nontiling)for apps needing it
for_window [class="Yad" instance="yad"] floating enable
for_window [class="Galculator" instance="galculator"] floating enable
for_window [class="Blueberry.py" instance="blueberry.py"] floating enable
#set floating (nontiling) for special apps
for_window [class="Xsane" instance="xsane"] floating enable
for_window [class="Pavucontrol" instance="pavucontrol"] floating enable
for_window [class="qt5ct" instance="qt5ct"] floating enable
for_window [class="Bluetooth-sendto" instance="bluetooth-sendto"] floating enable
for_window [class="Pamac-manager"] floating enable
# color settings for bar and windows #
# Define colors variables:
set $darkbluetrans #08052be6
set $darkblue #08052b
set $lightblue #5294e2
set $urgentred #e53935
set $white #ffffff
set $black #000000
set $purple #e345ff
set $darkgrey #383c4a
set $grey #b0b5bd
set $mediumgrey #8b8b8b
set $yellowbrown #e1b700
# define colors for windows:
#class border bground text indicator child_border
client.focused $lightblue $darkblue $white $purple $mediumgrey
client.unfocused $darkblue $darkblue $grey $purple $darkgrey
client.focused_inactive $darkblue $darkblue $grey $purple $black
client.urgent $urgentred $urgentred $white $purple $yellowbrown
# bar settings (input comes from i3blocks) #
# Start i3bar to display a workspace bar
# (plus the system information i3status finds out, if available)
bar {
font pango:Noto Sans Regular 10, FontAwesome 10
status_command i3blocks -c ~/.config/i3/i3blocks.conf
position top
# i3bar_command i3bar --transparency
# it could be that you have no primary display set: set one (xrandr --output <output> --primary)
# reference: https://i3wm.org/docs/userguide.html#_tray_output
tray_output primary
tray_padding 0
# When strip_workspace_numbers is set to yes,
# any workspace that has a name of the form
# “[n][:][NAME]” will display only the name.
strip_workspace_numbers yes
##strip_workspace_name no
colors {
separator $purple
background $darkgrey
statusline $white
# border bg txt indicator
focused_workspace $mediumgrey $grey $darkgrey $purple
active_workspace $lightblue $mediumgrey $darkgrey $purple
inactive_workspace $darkgrey $darkgrey $grey $purple
urgent_workspace $urgentred $urgentred $white $purple
# you can add different bars for multidisplay setups on each display:
# set output HDMI-0 to the display you want the bar, --transparency can be set.
# Transparency needs rgba color codes to be used where the last two letters are the transparency factor see here:
# https://gist.github.com/lopspower/03fb1cc0ac9f32ef38f4
# #08052be6 --> e6=90%
# bar {
# font pango:Noto Sans Regular 9, FontAwesome 9
# status_command i3blocks -c ~/.config/i3/i3blocks-2.conf
# output HDMI-0
# position bottom
#strip_workspace_numbers yes
# colors {
# separator $purple
# background $darkbluetrans
# statusline $white
# focused_workspace $lighterblue $lighterblue $darkblue $purple
# active_workspace $lightdblue $lightdblue $darkblue $purple
# inactive_workspace $darkblue $darkblue $lightdblue $purple
# urgent_workspace $urgentred $urgentred $white $purple
# Application menu handled by rofi: #
bindsym $mod+d exec rofi -modi drun -show drun \
-config ~/.config/rofi/rofidmenu.rasi
## rofi bindings for window menu (two bindings F10/$mod+t)
bindsym $mod+t exec rofi -show window \
What I am missing ? probably a lot ? xD
