Polkit driving my CPU crazy
I don’t know what exactly I’ve messed up, but polkitd is using a lot of CPU resources, and journalctl -u polkit outputs this:
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Unregistered Authentication Agent for unix-process:1067075:2231671 (system bus name :1.2632433, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8) (disconnected from bus)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Registered Authentication Agent for unix-process:1067099:2231672 (system bus name :1.2632439 [/usr/bin/pkttyagent --notify-fd 7 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Registered Authentication Agent for unix-process:1067095:2231672 (system bus name :1.2632438 [/usr/bin/pkttyagent --notify-fd 7 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Unregistered Authentication Agent for unix-process:1067099:2231672 (system bus name :1.2632439, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8) (disconnected from bus)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Registered Authentication Agent for unix-process:1067101:2231672 (system bus name :1.2632440 [/usr/bin/pkttyagent --notify-fd 7 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Registered Authentication Agent for unix-process:1067103:2231672 (system bus name :1.2632441 [/usr/bin/pkttyagent --notify-fd 7 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Unregistered Authentication Agent for unix-process:unknown (system bus name :1.2632438, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8) (disconnected from bus)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Unregistered Authentication Agent for unix-process:1067101:2231672 (system bus name :1.2632440, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8) (disconnected from bus)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Unregistered Authentication Agent for unix-process:1067103:2231672 (system bus name :1.2632441, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8) (disconnected from bus)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Registered Authentication Agent for unix-process:1067123:2231673 (system bus name :1.2632446 [/usr/bin/pkttyagent --notify-fd 7 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Registered Authentication Agent for unix-process:1067127:2231673 (system bus name :1.2632447 [/usr/bin/pkttyagent --notify-fd 7 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Unregistered Authentication Agent for unix-process:1067123:2231673 (system bus name :1.2632446, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8) (disconnected from bus)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Registered Authentication Agent for unix-process:1067129:2231673 (system bus name :1.2632448 [/usr/bin/pkttyagent --notify-fd 7 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Registered Authentication Agent for unix-process:1067131:2231673 (system bus name :1.2632449 [/usr/bin/pkttyagent --notify-fd 7 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8)
июн 05 19:24:21 glutesha-desktop polkitd[1055461]: Unregistered Authentication Agent for unix-process:unknown (system bus name :1.2632447, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8) (disconnected from bus)
… and it repeats endlessly.
What should I do?
Hi and welcome,
If we knew that the agent was being started/stopped on purpose then those would be normal messages.
If they are constant without a related known explanation then not so much.
Are there any other symptoms?
Are these messages new?
What is the makeup of the system?
inxi -Farz
Hello! This appears after 5 hours of uptime for some reason. It disappears after reboot, but it’s a temporary fix.
Here’s my system makeup:
  Kernel: 6.14.9-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    clocksource: tsc avail: hpet,acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux
    root=UUID=b7a700d9-dc4d-44fe-b794-ac6cea32d4ba rw rootflags=subvol=@
    "GRUB_CMDLINE_LINUX_DEFAULT=nowatchdog nvme_load=YES loglevel=3"
    nvidia_drm.modeset=1
  Desktop: Hyprland v: 0.49.0 with: waybar tools: hypridle avail: hyprlock
    vt: 1 dm: SDDM Distro: EndeavourOS base: Arch Linux
  Type: Desktop System: Gigabyte product: H510M H v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: H510M H v: x.x serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: F18
    date: 06/07/2023
  Info: model: Intel Core i5-10400 bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 3 microcode: 0x100
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 4001 min/max: 800/4300 scaling: driver: intel_pstate
    governor: powersave cores: 1: 4001 2: 4001 3: 4001 4: 4001 5: 4001 6: 4001
    7: 4001 8: 4001 9: 4001 10: 4001 11: 4001 12: 4001 bogomips: 69597
  Vulnerabilities:
  Type: gather_data_sampling mitigation: Microcode
  Type: ghostwrite status: Not affected
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: itlb_multihit status: KVM: Split huge pages
  Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
  Type: reg_file_data_sampling status: Not affected
  Type: retbleed mitigation: Enhanced IBRS
  Type: spec_rstack_overflow status: Not affected
    prctl
    sanitization
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] driver: nvidia
    v: 570.153.02 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none
    off: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2504
    class-ID: 0300
  Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: Hyprland v: 0.49.0 driver: X: loaded: nvidia
    unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
    gpu: nvidia,nvidia-nvswitch d-rect: 1920x1080 display-ID: 1
  Monitor-1: DP-1 pos: primary model: BenQ FP222Wa serial: <filter>
    built: 2007 res: mode: 1680x1050 hz: 60 scale: 100% (1) dpi: 91 gamma: 1.2
    size: 470x300mm (17.05x10.67") diag: 558mm (22") ratio: 16:10, 3:2 modes:
    max: 1680x1050 min: 640x350
  Monitor-2: HDMI-A-1 pos: primary model: LG (GoldStar) FULL HD
    serial: <filter> built: 2016 res: mode: 1920x1080 hz: 75 scale: 100% (1)
    dpi: 102 gamma: 1.2 size: 480x270mm (18.9x10.63") diag: 551mm (21.7")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
    x11: drv: nvidia inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.153.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
    memory: 11.72 GiB
  API: Vulkan v: 1.4.313 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3060 driver: nvidia v: 570.153.02
    device-ID: 10de:2504 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: nvidia-smi
    wl: nwg-displays,wayland-info x11: xdpyinfo, xprop, xrandr
  Device-1: Intel vendor: Gigabyte driver: snd_hda_intel v: kernel
    alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
  Device-4: BEHRINGER GmbH UMC204HD 192k driver: snd-usb-audio type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:6 chip-ID: 1397:0508
    class-ID: fe01
  Device-5: JMTek LLC. USB Condenser Microphone
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-8:8 chip-ID: 0c76:1718 class-ID: 0300
  API: ALSA v: k6.14.9-arch1-1 status: kernel-api
  Server-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctl
  Server-2: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    vendor: Gigabyte driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: tun2 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  Info: services: NetworkManager,systemd-timesyncd
Bluetooth:
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 2357:0604
    class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: N/A
  Local Storage: total: 1.94 TiB used: 568.5 GiB (28.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: 4B2QEXM7 temp: 31.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EARS-003BB1
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: N/A serial: <filter> fw-rev: 0A80
  ID-3: /dev/sdb maj-min: 8:16 vendor: Plextor model: PX-128S2C
    size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1.01 scheme: MBR
  ID-1: / raw-size: 246.86 GiB size: 246.86 GiB (100.00%)
    used: 46.6 GiB (18.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
    used: 616 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 246.86 GiB size: 246.86 GiB (100.00%)
  ID-4: /var/log raw-size: 246.86 GiB size: 246.86 GiB (100.00%)
  System Temperatures: cpu: 34.0 C mobo: 33.0 C
  Fan Speeds (rpm): N/A
Repos:
  Packages: 1416 pm: dpkg pkgs: 1 pm: pacman pkgs: 1405 libs: 358
    tools: pacseek,yay pm: flatpak pkgs: 10
  Active pacman repo servers in: /etc/pacman.d/chaotic-mirrorlist
    1: https://cdn-mirror.chaotic.cx/$repo/$arch
    2: https://geo-mirror.chaotic.cx/$repo/$arch
    3: https://br-mirror.chaotic.cx/$repo/$arch
    4: https://bg-mirror.chaotic.cx/$repo/$arch
    5: https://ca-mirror.chaotic.cx/$repo/$arch
    6: https://cl-mirror.chaotic.cx/$repo/$arch
    7: https://de-2-mirror.chaotic.cx/$repo/$arch
    8: https://de-3-mirror.chaotic.cx/$repo/$arch
    9: https://de-4-mirror.chaotic.cx/$repo/$arch
    10: https://fr-mirror.chaotic.cx/$repo/$arch
    11: https://gr-mirror.chaotic.cx/$repo/$arch
    12: https://in-mirror.chaotic.cx/$repo/$arch
    13: https://in-2-mirror.chaotic.cx/$repo/$arch
    14: https://in-3-mirror.chaotic.cx/$repo/$arch
    15: https://in-4-mirror.chaotic.cx/$repo/$arch
    16: https://kr-mirror.chaotic.cx/$repo/$arch
    17: https://es-mirror.chaotic.cx/$repo/$arch
    18: https://es-2-mirror.chaotic.cx/$repo/$arch
    19: https://us-mi-mirror.chaotic.cx/$repo/$arch
    20: https://us-tx-mirror.chaotic.cx/$repo/$arch
    21: https://us-ut-mirror.chaotic.cx/$repo/$arch
  Active pacman repo servers in: /etc/pacman.d/endeavouros-mirrorlist
    1: https://mirror.accum.se/mirror/endeavouros/repo/$repo/$arch
    2: https://mirror.moson.org/endeavouros/repo/$repo/$arch
    3: https://pkg.adfinis-on-exoscale.ch/endeavouros/repo/$repo/$arch
    4: https://ftp.rz.tu-bs.de/pub/mirror/endeavouros/repo/$repo/$arch
    5: https://repo.c48.uk/endeavouros/repo/$repo/$arch
    6: https://mirror.alpix.eu/endeavouros/repo/$repo/$arch
    7: https://mirror.rznet.fr/endeavouros/repo/$repo/$arch
    8: https://mirror.gofoss.xyz/endeavouros/repo/$repo/$arch
    9: https://ftp.belnet.be/mirror/endeavouros/repo/$repo/$arch
    10: https://fosszone.csd.auth.gr/endeavouros/repo/$repo/$arch
    11: https://mirror.leitecastro.com/endeavouros/repo/$repo/$arch
    12: https://mirrors.gigenet.com/endeavouros/repo/$repo/$arch
    13: https://mirror.nag.albony.in/endeavouros/repo/$repo/$arch
    14: https://mirrors.urbanwave.co.za/endeavouros/repo/$repo/$arch
    15: https://mirrors.nxtgen.com/endeavouros-mirror/repo/$repo/$arch
    16: https://mirror.freedif.org/EndeavourOS/repo/$repo/$arch
    17: https://mirror.archlinux.tw/EndeavourOS/repo/$repo/$arch
    18: https://mirror.b-interactive.com.au/endeavouros/repo/$repo/$arch
    19: https://mirror.funami.tech/endeavouros/repo/$repo/$arch
    20: https://mirrors.jlu.edu.cn/endeavouros/repo/$repo/$arch
    21: https://www.miraa.jp/endeavouros/repo/$repo/$arch
    22: https://mirrors.tuna.tsinghua.edu.cn/endeavouros/repo/$repo/$arch
  Active pacman repo servers in: /etc/pacman.d/mirrorlist
    1: http://cdnmirror.com/archlinux/$repo/os/$arch
    2: http://at.mirrors.cicku.me/archlinux/$repo/os/$arch
    3: https://cdnmirror.com/archlinux/$repo/os/$arch
    4: http://mirror.ourhost.az/archlinux/$repo/os/$arch
    5: http://us.arch.niranjan.co/$repo/os/$arch
    6: http://br.mirrors.cicku.me/archlinux/$repo/os/$arch
    7: http://de.arch.niranjan.co/$repo/os/$arch
    8: http://ch.mirrors.cicku.me/archlinux/$repo/os/$arch
    9: http://repository.su/archlinux/$repo/os/$arch
    10: https://es.mirrors.cicku.me/archlinux/$repo/os/$arch
    11: https://it.mirrors.cicku.me/archlinux/$repo/os/$arch
    12: https://mirrors.dotsrc.org/archlinux/$repo/os/$arch
    13: http://it.mirrors.cicku.me/archlinux/$repo/os/$arch
    14: http://es.mirrors.cicku.me/archlinux/$repo/os/$arch
    15: http://mirror.trap.moe/archlinux/$repo/os/$arch
    16: https://nl.arch.niranjan.co/$repo/os/$arch
    17: https://mirror.ourhost.az/archlinux/$repo/os/$arch
    18: http://mirrors.dotsrc.org/archlinux/$repo/os/$arch
    19: https://mirror.quantum5.ca/archlinux/$repo/os/$arch
    20: https://tr.arch.niranjan.co/$repo/os/$arch
    21: https://arch.jsc.mx/$repo/os/$arch
    22: http://al.arch.niranjan.co/$repo/os/$arch
    23: http://sg.mirrors.cicku.me/archlinux/$repo/os/$arch
    24: https://mirror.cyberbits.eu/archlinux/$repo/os/$arch
    25: https://al.arch.niranjan.co/$repo/os/$arch
    26: http://arch.sakamoto.pl/$repo/os/$arch
    27: https://london.mirror.pkgbuild.com/$repo/os/$arch
    28: https://mirror.1ago.be/archlinux/$repo/os/$arch
    29: https://archlinux.uk.mirror.allworldit.com/archlinux/$repo/os/$arch
    30: http://mirror.neuf.no/archlinux/$repo/os/$arch
    31: https://de.arch.niranjan.co/$repo/os/$arch
    32: https://mirror.bahnhof.net/pub/archlinux/$repo/os/$arch
    33: http://mirror.nw-sys.ru/archlinux/$repo/os/$arch
    34: http://mirror.telepoint.bg/archlinux/$repo/os/$arch
    35: http://ro.arch.niranjan.co/$repo/os/$arch
    36: http://mirror.1ago.be/archlinux/$repo/os/$arch
    37: https://at.arch.niranjan.co/$repo/os/$arch
    38: http://mirror.nl.cdn-perfprod.com/archlinux/$repo/os/$arch
    39: https://europe.mirror.pkgbuild.com/$repo/os/$arch
    40: http://archmirror.hbit.sztaki.hu/archlinux/$repo/os/$arch
    41: http://mirror.bahnhof.net/pub/archlinux/$repo/os/$arch
    42: https://mirror.tux.si/arch/$repo/os/$arch
    43: http://ftp.rnl.tecnico.ulisboa.pt/pub/archlinux/$repo/os/$arch
    44: https://mirror.cspacehostings.com/archlinux/$repo/os/$arch
    45: https://mirror.przekichane.pl/archlinux/$repo/os/$arch
    46: http://ossmirror.mycloud.services/os/linux/archlinux/$repo/os/$arch
    47: http://arch.mirror.constant.com/$repo/os/$arch
    48: https://mirror.neuf.no/archlinux/$repo/os/$arch
    49: http://mirror.cspacehostings.com/archlinux/$repo/os/$arch
    50: https://mirrors.atviras.lt/archlinux/$repo/os/$arch
    51: http://jp.mirrors.cicku.me/archlinux/$repo/os/$arch
    52: http://mirrors.atviras.lt/archlinux/$repo/os/$arch
    53: https://jp.mirrors.cicku.me/archlinux/$repo/os/$arch
    54: https://ftp.rnl.tecnico.ulisboa.pt/pub/archlinux/$repo/os/$arch
    55: http://mirror.quantum5.ca/archlinux/$repo/os/$arch
    56: https://ro.arch.niranjan.co/$repo/os/$arch
    57: http://mirror.tux.si/arch/$repo/os/$arch
    58: https://mirror.telepoint.bg/archlinux/$repo/os/$arch
    59: http://mirror.xtom.com.hk/archlinux/$repo/os/$arch
    60: http://ftp.sh.cvut.cz/arch/$repo/os/$arch
    61: https://archlinux.interhost.co.il/$repo/os/$arch
    62: https://mirror.del2.albony.in/archlinux/$repo/os/$arch
    63: http://archlinux.interhost.co.il/$repo/os/$arch
    64: http://mirrors.neusoft.edu.cn/archlinux/$repo/os/$arch
    65: https://mirrors.saswata.cc/archlinux/$repo/os/$arch
    66: https://theswissbay.ch/archlinux/$repo/os/$arch
  Memory: total: 32 GiB available: 31.2 GiB used: 3.4 GiB (10.9%)
  Processes: 354 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.42 GiB services: power-profiles-daemon
    Init: systemd v: 257 default: graphical tool: systemctl
  Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: kitty
    inxi: 3.3.38
How can i investigate this further?
