I have tried many times to install the client of the poker platform GGPoker. However, with no version of wine I have ever successfully done so. The installation seems to download a few things, then suddenly hangs - as in doesn’t continue anymore, and the window is not updated anymore.
As the log below doesn’t seem to show anything that looks like it would stop the installation process (all err type messages appear multiple times), and as the last message is a fixme type message, it doesn’t look like I can from that log gleam what the problem is.
I know there is a full logging setting, however, that seems to segfault every time I try that (from the lutris GUI). How would I try to find out why the application doesn’t install?
lutris-wrapper: ggpoker
Started initial process 1449037 from gamemoderun /usr/bin/wine msiexec /i /home/dromundkaas/Games/ggpoker/drive_c/temp/Installer_GGPoker_de.msi
Start monitoring process.
ERROR: ld.so: object 'libgamemodeauto.so.0' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
esync: up and running.
002c:fixme:winediag:LdrInitializeThunk wine-staging 7.20 is a testing version containing experimental patches.
002c:fixme:winediag:LdrInitializeThunk Please mention your exact version when filing bug reports on winehq.org.
008c:fixme:hid:handle_IRP_MN_QUERY_ID Unhandled type 00000005
0078:fixme:imm:ImeSetActiveContext (0000000000010026, 0): stub
0078:fixme:imm:ImmReleaseContext (0000000000010020, 0000000000010026): stub
002c:fixme:imm:ImeSetActiveContext (000000000001005E, 1): stub
002c:fixme:imm:ImmReleaseContext (000000000001005C, 000000000001005E): stub
0110:fixme:file:NtLockFile I/O completion on lock not implemented yet
0110:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0118:fixme:imm:ImeSetActiveContext (0000000000010094, 1): stub
0118:fixme:imm:ImmReleaseContext (000000000001009C, 0000000000010094): stub
0118:fixme:urlmon:InternetBindInfo_GetBindString not supported string type 20
0118:fixme:file:NtLockFile I/O completion on lock not implemented yet
0118:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
012c:fixme:file:NtLockFile I/O completion on lock not implemented yet
012c:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0134:fixme:file:NtLockFile I/O completion on lock not implemented yet
0134:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0134:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 5)
014c:fixme:file:NtLockFile I/O completion on lock not implemented yet
014c:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
014c:err:mscoree:LoadLibraryShim error reading registry key for installroot
015c:fixme:imm:ImeSetActiveContext (00000000000300C0, 1): stub
015c:fixme:imm:ImmReleaseContext (00000000000400BA, 00000000000300C0): stub
014c:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 5)
0118:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 1)
0184:fixme:msg:pack_message msg 14 (WM_ERASEBKGND) not supported yet
wine: configuration in L"home/dromundkaas/Games/ggpoker" has been updated.
0194:fixme:file:NtLockFile I/O completion on lock not implemented yet
0194:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0194:fixme:imm:ImeSetActiveContext (00020074, 1): stub
0194:fixme:imm:ImmReleaseContext (00050062, 00020074): stub
0194:fixme:msi:ACTION_CustomAction msidbCustomActionTypeTSAware not handled
0194:err:msi:execute_command unable to execute command 2
0194:fixme:msi:ITERATE_CreateShortcuts poorly handled shortcut format, advertised shortcut
0194:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 5)
Initial process has exited (return code: 0)
01b8:fixme:kernelbase:AppPolicyGetThreadInitializationType FFFFFFFA, 01D0FEF8
01b8:fixme:wininet:InternetSetOptionW INTERNET_OPTION_SEND/RECEIVE_TIMEOUT/DATA_SEND_TIMEOUT 5000
01b8:fixme:wininet:InternetSetOptionW Option INTERNET_OPTION_DATA_RECEIVE_TIMEOUT (5000): STUB
01b8:fixme:wininet:InternetSetOptionW Option 11 STUB
01b4:fixme:imm:ImeSetActiveContext (0005005A, 1): stub
01b4:fixme:imm:ImmReleaseContext (00040072, 0005005A): stub
01b8:fixme:secur32:get_cipher_algid unknown algorithm 23
01b8:fixme:secur32:get_mac_algid unknown algorithm 200, cipher 23
01b8:fixme:wininet:set_cookie Unknown additional option L"SameSite=None; Secure"
01b8:fixme:wininet:set_cookie secure not handled
01b8:err:wininet:HTTP_ParseDateAsAsctime unexpected weekday L"-1"
01b8:err:wininet:HTTP_ParseDate unexpected date format L"-1"
01c0:fixme:wininet:InternetSetOptionW INTERNET_OPTION_SEND/RECEIVE_TIMEOUT/DATA_SEND_TIMEOUT 5000
01c0:fixme:wininet:InternetSetOptionW Option INTERNET_OPTION_DATA_RECEIVE_TIMEOUT (5000): STUB
01c0:fixme:wininet:InternetSetOptionW Option 11 STUB
01c0:err:wininet:HTTP_ParseDateAsAsctime unexpected weekday L"-1"
01c0:err:wininet:HTTP_ParseDate unexpected date format L"-1"
01c0:fixme:msg:pack_message msg 14 (WM_ERASEBKGND) not supported yet
