hook
September 11, 2023, 11:00pm
1
I have the following in /etc/vconsole.conf
KEYMAP=slovene
FONT=spleen-12x24
FONT_MAP=8859-2
And it works fine.
Well, it did, until I installed Plymouth. Now the TTY is again the wrong (i.e. default) FONT
and FONT_MAP
If I remove splash
from the kernel parameters when booting, the font is again Spleen with 8859-2 map. So I highly suspect Plymouth here.
Any idea what’s happening and how do I fix it?
dalto
September 11, 2023, 11:26pm
2
Is it being pulled into your initrd? What lsinitd | grep vconsole
show?
hook
September 12, 2023, 4:42am
3
sudo lsinitrd | grep vconsole
says:
lrwxrwxrwx 1 root root 54 Sep 12 00:38 etc/systemd/system/rescue.target.wants/systemd-vconsole-setup.service -> /usr/lib/systemd/system/systemd-vconsole-setup.service
lrwxrwxrwx 1 root root 54 Sep 12 00:38 etc/systemd/system/systemd-ask-password-console.service.wants/systemd-vconsole-setup.service -> /usr/lib/systemd/system/systemd-vconsole-setup.service
lrwxrwxrwx 1 root root 54 Sep 12 00:38 etc/systemd/system/systemd-ask-password-plymouth.service.wants/systemd-vconsole-setup.service -> /usr/lib/systemd/system/systemd-vconsole-setup.service
-rw-r--r-- 1 root root 49 Sep 11 07:26 etc/vconsole.conf
-rwxr-xr-x 1 root root 22648 Sep 9 22:19 usr/lib/systemd/systemd-vconsole-setup
-rw-r--r-- 1 root root 894 Sep 9 22:19 usr/lib/systemd/system/systemd-vconsole-setup.service
-rw-r--r-- 1 root root 518 Sep 9 22:19 usr/lib/udev/rules.d/90-vconsole.rules
dalto
September 12, 2023, 11:00am
4
It appears to be in there.
What is your dracut config? cat /etc/dracut.conf.d/*
hook
September 12, 2023, 8:36pm
5
# Configuration file automatically written by the Calamares system installer
# (This file is written once at install time and should be safe to edit.)
# Enables support for LUKS full disk encryption with single sign on from GRUB.
# force installing /etc/crypttab even if hostonly="no", install the keyfile
install_items+=" /etc/crypttab /crypto_keyfile.bin "
# enable automatic resume from swap
add_device+=" /dev/disk/by-uuid/f9afd717-fdc8-4b81-8ada-6207724a9dec "
omit_dracutmodules+=" network cifs nfs brltty "
compress="zstd"
add_dracutmodules+=" plymouth "
add_dracutmodules+=" resume "
dalto
September 12, 2023, 8:50pm
6
Can we see the output of inxi -Gxxxz
hook
September 12, 2023, 8:54pm
7
Of course!
Device-1: AMD Lucienne vendor: Tongfang Hongkong driver: amdgpu v: kernel
arch: GCN-5 pcie: speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 off: eDP-1
empty: DP-1 bus-ID: 05:00.0 chip-ID: 1002:164c class-ID: 0300 temp: 39.0 C
Device-2: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 1-3:2 chip-ID: 04f2:b71a class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary model: AOC 24G2W1G4
serial: <filter> res: 1920x1080 dpi: 93 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 mapped: eDP note: disabled model: ChiMei InnoLux 0x14d5
res: 1920x1080 dpi: 158 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: AMD Radeon Graphics
(renoir LLVM 16.0.6 DRM 3.54 6.5.2-zen1-1-zen) direct-render: Yes
dalto
September 12, 2023, 9:00pm
8
Can you try early loading amdgpu.
Add this to a config file:
force_drivers+=" amdgpu "
Then run sudo dracut-rebuild
hook
September 12, 2023, 9:11pm
9
This seems to have worked, thanks.
Should I keep it as is now – with the force_drivers
dalto
September 12, 2023, 9:15pm
10
Yes, that just loads your GPU drivers earlier in the process.
system
Closed
September 14, 2023, 9:15pm
11
