Plymouth not working on start up
Using systemd-boot and dracut. I want to set a splash screen, so I did the following:
  1. Install
yay -S plymouth-git plymouth-kcm breeze-plymouth
  1. Configure dracut
$ cat /etc/dracut.conf.d/myflags.conf
add_dracutmodules+=" plymouth "
  1. Configure systemd-boot
$ cat /etc/kernel/cmdline
nvme_load=YES nowatchdog rw rootflags=subvol=/@ root=UUID=60e03a50-4407-4d46-a548-fcdfd4464dad quiet loglevel=3 splash
  1. Configure plymouth
sudo plymouth-set-default-theme bgrt
  1. Generate new init boot image
$ sudo reinstall-kernels
But the problem is I seem to see the setup when restarting/shutting down, but not on start up. Am I missing something?
What is your GPU?
An AMD Ryzen 7900
You could try early loading your GPU drivers in dracut and see if that helps.
There is an example in the drauct wiki article on Discovery.
Thank you! That did it. Here’s the updated step by step in case anyone else has this issue:
  1. Install
  1. Configure dracut
force_drivers+=" amdgpu "
$ cat /etc/plymouth/plymouthd.conf
[Daemon]
Theme=bgrt
DeviceTimeout=8
ShowDelay=0
DeviceScale=2
