Hey all, I got a laptop with a non-eng keyboard and there is annoyingly an extra key between left shift and z that I keep hitting when I mean to hit left shift. I would like to remap this button to do what left shift does.
Using the showkey command I have found that the keycode of this button is 86 and the keycode of left shift is 42.
I tried "xmodmap -e “keycode 86 = Shift_L” but it doesn’t seem to do anything.
Any assistance would be really great. Note I don’t wanna switch this key with left shift, I want them both to do what shift does.
I installed a program called xkeycaps which allows you to graphically remap keys. This creates a hidden file in your home dir called .xmodmap-blablah. To make it persistent across reboots you need to create a script with the command “xmodmap /home/user/.xmodmap-blahblah” and have that script automatically run on startup.
I am not sure if this is the best way to do this, but it works for me.
