Plasma freezing on splashscreen after logging in
Pretty much as the title states.
I can ctrl+alt+f2 to get to the terminal.
I can log into xfce fine as well.
Any ideas how I can debug this?
Are you using a non-standard kwin? kwinft or low latency?
do in Xfce alt-f2 , kwin_x11 --replace , if its freeze then is highly kwin. so not could be a service. you try set baloo of if that isnt the case…
I was using kwin low latency, and kwin crashed leading to me rebooting and the problem started.
I did try replacing kwin low latency with standard kwin but that didn’t fix it.
nothing happens when I try kwin_x11 --replace from application finder.
when I try from the terminal I get:
[duncanm@arch ~]$ kwin_x11 --replace
kwin_x11: symbol lookup error: /usr/lib/libkwin.so.5: undefined symbol: _ZN14KWaylandServer18TextInputInterface6commitERK10QByteArray
[duncanm@arch ~]$
if you install openbox and start kde with openbox session; probably stil freezing…? mayby is something in autostart that crashes…
I actually went back to a backup in the end as this didn’t look like it would be an easy fix.
ah wel just narrow the issue i would say… with openbox there is a session to start, so you can say is not WM issue, mayby something that starts up… i you can try even disable the splash screen , or it has to do with the theme…
after upgrading to the latest plasma I have a very long lag on the first login after that, it could be simple also some settings changed. I would take a look at the journal also.
I’d been running 5.20 via unstable, had then upgraded to 5.20 stable already before this happened.
XFCE flickers horrifically even if I set it to 120MHz so as I had some work to do getting a functioning desktop was pretty urgent, hence going to the backup.
This all sounds like a partial upgrade:
Says that library is the wrong version, because it cannot find that symbol.
Mines not freezing but when i log in and it goes to the desktop screen it flashes a small screen of the same background and a black bar under it at the bottom left near the menu. Happens on every new start & log in but not if i log out and back in.
this not like partial its kwin zelf
[> ringo@Godofhighschool ~]$ pkgfile /usr/lib/libkwin.so.5
extra/kwin
[ringo@Godofhighschool ~]$
Yes,but the op was running low latency, this probably caused the wrong library to be installed
