after the update yesterday i can log in to plasma via sddm but the interface does not start. i cannot right click with the mouse on the blank screen and the panel does not start. The empty space above should be the panel.
The programs i have started with krunner. That works
After entry
kstart5 plasmashell
i have this output
Omitting both --window and --windowclass arguments is not recommended
Solved!
I had installed from the AUR window-tiled-menu and tried after the update yesterday. so it has nothing to do with update. i have window-tiled-menu, also looks kind of funny, uninstalled again and voila, everything works again.
This is exactly what i have been saying all along about Kde Plasma. You start changing things and it goes screwy. So it’s not a problem now you know. That doesn’t work so you probably won’t use it.
i was looking for an alternative to the plasma launcher. unfortunately i forgot to deactivate the tiled launcher after testing it. the next morning i realized it wasn’t working and remembered not to deactivate it. so all in all it was my fault.
