PiVPN, Wireguard and Endeavour -- I'm at my ropes end. Help!
Hi there,
I really don’t know what is going on, but I simply can’t get my EndeavourOS client to properly connect to my Wireguard through PiVPN. I have absolutely no problems with the connection on my cell phone from the same external network to the very same VPN endpoint.
I followed the steps outlined in this document, started the connect and it works, but I have no internet. It’s even more weird when running pings into different IPs. I get correct ping returns from 192.168.1.1, 1.1.1.1 and 8.8.8.8, but everything else fails. E.g. 192.168.1.31 (the location of the PiVPN) returns “Destination Host Unreachable”. My HTPC sitting on the same network as well. And a ping to www.google.com comes back with “Temporary failure in name resolution”.
What is going on?!?!
What’s different in their configuration?
That’s the confusing part: Aside from keys and the corresponding address, they are exactly alike. I would expect the same type of connection as on the phone.
That’s why I’m posting here, it seems to be something on client peer…
