I can’t make Pipewire work on a new OS install and I’ve spent well over two hours now attempting every possible fix I’ve found on the web with absolutely no results. Pipewire is running, but there are no audio devices available.
I have Wireplumber, pipewire, and pipewire-pulse installed. All three are running.
I have purged all their configs and reinstalled all of them including their dependencies.
pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2022-04-25 07:05:18 CEST; 5min ago
TriggeredBy: ● pipewire-pulse.socket
Main PID: 623 (pipewire-pulse)
Tasks: 2 (limit: 19066)
Memory: 6.4M
CPU: 12ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
└─623 /usr/bin/pipewire-pulse
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; vendor preset: enabled)
Active: active (running) since Mon 2022-04-25 07:05:18 CEST; 3min 40s ago
TriggeredBy: ● pipewire.socket
Main PID: 621 (pipewire)
Memory: 5.4M
CPU: 18ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─621 /usr/bin/pipewire
● wireplumber.service - Multimedia Service Session Manager
Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; vendor preset: enabled)
Main PID: 622 (wireplumber)
Tasks: 4 (limit: 19066)
Memory: 13.7M
CPU: 91ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
└─622 /usr/bin/wireplumber
The wireplumber service also spits out this which (presumably?) is what is causing it:
Apr 25 07:05:18 main systemd[612]: Started Multimedia Service Session Manager.
Apr 25 07:05:18 main wireplumber[622]: can't open control for card hw:2: No such file or directory
Apr 25 07:05:18 main wireplumber[622]: Card can't get card_name from card_index 1
Apr 25 07:05:19 main wireplumber[622]: can't open control for card hw:1: No such file or directory
Solutions, please?
