Hi
I have setup Pi-Hole and Unbound on my local LAN(phisical Pi-3 pluged lan
direct to router), this works perfectly
until reboot(EOS-Plasma) then I have no network. The only thing then seems
to be to reset the router Pin in back, and a further reboot of EOS-Plasma. This
results in the Comp(EOS) being able to see the router
I can tell by logs on the Pi-Hole that everything is working fine until reboot, any
ideas?
Obviously I am trying to block adds on a network wide basis, I am not altering the config ip’s
of EOS Lan connection. I would rather not have the pain of configuring every machine on the
network individually.
Data
