I think I am trying as a normal user
does sudo faillock
return anything?
When Type Source Valid
user1:
2022-09-05 10:39:04 TTY /dev/tty1 V
2022-09-05 10:39:15 TTY /dev/tty1 V
2022-09-05 10:39:21 TTY /dev/tty1 V
It looks like your account may be locked…
sudo faillock --user user1 --reset
oh so what next?
Reboot?
@EndevourOS ~]$ sudo faillock --user user1 reset
faillock: Unknown option: reset
Usage: faillock [--dir /path/to/tally-directory] [--user username] [--reset]
ok - if I reboot then it means I need to go to sleep
Me too!
thank you both @anon11595408 and @dalto
I’ll shut the engine down and see what comes tomorrow
you’ve been very helpful
By tomorrow, the locks should expire on their own.
many thanks for the helping
