gnome-disks is the command
weird, how come i type gnome-disk âtabâ and gnome-disks does not come out ?
darn it, how do i type this in forum ? it wonât let me post this.
is 64GB plenty enough for / drive ? linux wonât prompt me "out of space " in future ?
Depends on your usage . If you store videos and other large files consider larger sizes . Mine with snapshots use 22 GB . So 64 GB may hold . You can expand the partition in the future .
Maybe you donât have it installed?
Use preformatted text tags. Highlight the text you want to be formatted and then click the button in the toolbar that looks like </>
Or you can use <kbd>Tab</kbd>
to have it rendered fancy like this: Tab
They say you learn something new every day. This was it for me. Now I can go into comatose mode for the rest of the day.
Pudge
snapshots ? snapshots are refering to os snapshots or screenshot ?
i wonât store video files on / partition.
if my hdd already partitioned, no space left unuse in between the partition, it is not possible to expand ⌠right ?
i am login via life usb. i am ready to reinstall enos in plasma dE, but i want to know my partition for / is big enough or notâŚ
64GB for / is more than enough, assuming youâre still planning to use a separate /home.
Go for it.
hee. thx. a bit late. i increased / partition to 80GB because no one reply on time⌠and i want to get it install before i sleep.
anyway a bit bigger is⌠no harm.
