Hello, switched form SparkyOS to Eos recently, still have Sparky in a partition. Eos works as it should but have been playing around with partitions to learn. Here’s where I am now:
Device Start End Sectors Type-UUID UUID Name Attrs
/dev/sda1 4096 618495 614400 C12A7328-F81F-11D2-BA4B-00A0C93EC93B 7607B6D0-2415-7D47-8610-B5B7C4176A6F
/dev/sda2 618496 977069280 976450785 0FC63DAF-8483-4772-8E79-3D69D8477DE4 1C437977-265B-8049-841D-CC0108F6E544 sparkyos
/dev/sda3 977069282 979117281 2048000 C12A7328-F81F-11D2-BA4B-00A0C93EC93B E5833C6C-7DF7-AF4C-B949-797C260DAD67
/dev/sda4 979117282 1953520064 974402783 0FC63DAF-8483-4772-8E79-3D69D8477DE4 B8381D9F-4CB8-2745-9975-2CFE962D89B9 endeavouros
/dev/sda5 2048 4095 2048 0FC63DAF-8483-4772-8E79-3D69D8477DE4 C9F00BFD-ACA3-B240-A086-320F0359F148
Partition 3 does not start on physical sector boundary.
Partition 4 does not start on physical sector boundary.
Partition table entries are not in disk order.
Using KDE Partition Manager I started out just wanting to use unallocated space which sda5 was until I converted it to its own partition and ext4; still have 2.48 MiB on unallocated elsewhere. It doesn’t amount to much but want to do something with it. What’s a good use for unallocated space?
ALSO sda1 is fat32 NO-LABEL 300 MiB, and sda3 is fat32 1,000 MiB with mount point in /eft but not mounted. Not sure what either of these are; should I leave them as is?
Thanks much.
