I’m just trying to help! Giving you ideas. I don’t know what the issue is. It could be something you are overlooking or not? ![]()
@Pozitigor
Does the printer have the ability to be used on usb?
I think the problem I made was the firewall that I was being asked to use by default printer programs. Do you know how to disable it?
No I’m not that familiar with it. You’ll have to look at the wiki for the documentation.
https://discovery.endeavouros.com/applications/firewalld/2022/03/
I’ll try to reinstall os, but i will turn off firewallid in package installer.
As soon as i run the system i will send here a message
It worked! Hurray!
All I have to do is disable the firewallid installation option and install KDE plasma or another de with printer manager and install the pantum_driver package in the OS.
So, I have a third option to configure my printer, which worked perfectly!
Thank you for your help!
I knew there was something simple.
