EDIT: I am still making modifications to this post, hit enter and posted prematurely…
EndeavourOS fully up to date - Plasma 5.24.1, Frameworks 5.91, QT 5.15, Kernel 5.16.9
Panon widget version 0.4.6
Music be bumpin, but my soundbar not thumpin. There is a “debug” option within the Panon widget but I’m not sure what this actually does, or where any log files are that could be examined.
I had the soundbar working before migrating from Kubuntu → Endeavour (I’ve distro hopped a few times last couple months because (reasons)).
On “Back-End”, I’ve tried changing between PulseAudio and PortAudio, as well as changing input devices and frequency ranges but nothing seems to pick up the output devices for the visualizer.
The only thing I’ve noticed that “works” is if I have Portaudio selected and my microphones unmuted, and then it appears that Panon picks up the ambient noise that my microphones are picking up.
I’ve made sure all dependencies are installed:
qt5-websockets \
python-docopt python-numpy python-pyaudio python-cffi python-websockets
And here is my lspci output:
00:00.0 Host bridge: Intel Corporation Coffee Lake HOST and DRAM Controller (rev 0c)
00:02.0 VGA compatible controller: Intel Corporation WhiskeyLake-U GT2 [UHD Graphics 620] (rev 02)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 0c)
00:12.0 Signal processing controller: Intel Corporation Cannon Point-LP Thermal Controller (rev 11)
00:13.0 Serial controller: Intel Corporation Cannon Point-LP Integrated Sensor Hub (rev 11)
00:14.0 USB controller: Intel Corporation Cannon Point-LP USB 3.1 xHCI Controller (rev 11)
00:14.2 RAM memory: Intel Corporation Cannon Point-LP Shared SRAM (rev 11)
00:15.0 Serial bus controller: Intel Corporation Cannon Point-LP Serial IO I2C Controller #0 (rev 11)
00:15.1 Serial bus controller: Intel Corporation Cannon Point-LP Serial IO I2C Controller #1 (rev 11)
00:16.0 Communication controller: Intel Corporation Cannon Point-LP MEI Controller #1 (rev 11)
00:16.3 Serial controller: Intel Corporation Cannon Point-LP Keyboard and Text (KT) Redirection (rev 11)
00:17.0 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 11)
00:1c.0 PCI bridge: Intel Corporation Cannon Point-LP PCI Express Root Port #5 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Cannon Point-LP PCI Express Root Port #9 (rev f1)
00:1d.4 PCI bridge: Intel Corporation Cannon Point-LP PCI Express Root Port #13 (rev f1)
00:1d.6 PCI bridge: Intel Corporation Cannon Point-LP PCI Express Root Port #15 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Cannon Point-LP LPC Controller (rev 11)
00:1f.3 Multimedia audio controller: Intel Corporation Cannon Point-LP High Definition Audio Controller (rev 11)
00:1f.4 SMBus: Intel Corporation Cannon Point-LP SMBus Controller (rev 11)
00:1f.5 Serial bus controller: Intel Corporation Cannon Point-LP SPI Controller (rev 11)
01:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
02:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
02:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
02:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
02:04.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 4C 2018] (rev 06)
04:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge DD 2018] (rev 06)
05:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge DD 2018] (rev 06)
05:04.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge DD 2018] (rev 06)
06:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 4C 2018] (rev 06)
37:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 4C 2018] (rev 06)
6c:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
6d:00.0 Non-Volatile memory controller: Intel Corporation Device 0975 (rev 03)
6e:00.0 Non-Volatile memory controller: Intel Corporation Device 0975
Any ideas are greatly appreciated - Please let me know if there are any logs or further information for me to gather.
