Panel Icon Size Difference/Padding between 46 & 48
I posted this in the KDE forum but silence so far. I’m trying to reduce my panel size to something below 48 but when doing so the icons in the system tray and on the the right side of the center spacer shrink much more than the actual panel scaling, creating large padding top and bottom of the icons.
This happens on every KDE install on different distros I’ve done.
The icons left of the spacer (open applications) scale much more in line with panel size.
Size 46 on top, 48 on bottom.
46 48 1
Operating System: EndeavourOS
KDE Plasma Version: 6.4.5
KDE Frameworks Version: 6.18.0
Qt Version: 6.10.0
Kernel Version: 6.17.1-arch1-1 (64-bit)
Graphics Platform: Wayland
Processors: 32 × AMD Ryzen 9 5950X 16-Core Processor
Memory: 64 GiB of RAM (62.7 GiB usable)
Graphics Processor: AMD Radeon RX 7600 XT
System Tray configuration has option for “Panel icon size (‘Small’ or ‘Scale with Panel height’)”.
Yes, this what I’m talking about, not scaling correctly. When choosing this option the icons scale much smaller than the panel height.
