Hey all,
Just a quick little update, the developer for yay
got back to me and had this to say:
Github Explanation from Jguer - developer
yay -Y --gendb
creates the file~/.cache/yay/vcs.json
with the latest SHA of the origin for each-git
package. It gives a starting point foryay
to start checking devel upgrades. At this point foryay
it does think that you have the latest upstream version installed (even if you do not).When you run
yay -Syu --devel
, yay checks again all of the remote SHAs against~/.cache/yay/vcs.json
and proposes the package for upgrade if they differ.Hopefully if you use yay on a regular basis once the upstream SHA of a -git package has changed, it will be proposed by yay, youâll install it and yay will update its entry in
.Itâs a matter of eventual consistency so
yay -Y --gendb
just tells yay to assume all those-git
packages have their latest version installed.
So what does this mean exactly? Well, essentially the tl;dr is after the first time that yay -Y --gendb
is run, anything after that then yay
will see the git update, but since I just did it for the first time today, everything looks up to date. So essentially the next time that popsicle-git
has an update, that is when yay
will for sure see the update.
A little bit confusing at first to not know that, but thatâs more or less how yay
operates by design so I wouldnât say this is a bug/issue. For myself Iâll just update popsicle-git
through Pamac for now and the next time popsicle-git
gets an update, yay
should be able to see it the next time when it compares it to itâs own database. Time will tell! Hope this is helpful to yâall and hope everyone has a great weekend
