Greetings lovely community,
I’ve had this issue for about two days now. Didn’t think too much of it initially, but I wanted to see if anyone else was having a similar issue or if it was somehow just me experiencing the issue. I’m using pamac-aur --version 10.1.3-1
, and when I use the tab to check Updates, normally it would return results in about 10-15 seconds. However, for the last two or so days, it takes about a minute to a minute and a half to check for updates before results are finally displayed. A similar thing happens when I run pamac checkupdates
from the terminal and it takes about a minute before results are displayed.
My internet is fiber 1GB, though I am on wifi so my speeds typically range around ~150MBps, which is more than enough. I’m not downloading, uploading, or seeding anything so I don’t believe it has anything to do with my connection. I’m assuming it may be the result of some recent updates perhaps, but I’m not too sure (looks at iproute2
with curious eyes). I haven’t found anyone else mention this issue before, so it could be just me.
A curious quick glance over at the Manjaro forums (since they develop Pamac) shows from their recent updates there were a few users with some Pamac issues, but nothing that I could track down that was quite related to what I am experiencing.
When updating, pamac-aur
will hover at 90% on this screen for about a minute before results finally show up. Normally in the past this should take only about 10 seconds.
Curiously enough, when I run checkupdates
I get results almost instantly. However when I run pamac checkupdates
it once again takes about a minute before results appear.
I don’t know if it matters at all, but sometimes when updating, I have System Monitor open and I’ll see the process makepkg
spikes the CPU for a brief moment, but I assume that’s probably normal behavior.
Here’s just the most recent updated packages I did in case anything strikes someone’s eyes. I don’t know if any of the recent package updates could be the culprit or not, but figured it couldn’t hurt to post this as well.
Output for grep -i upgraded /var/log/pacman.log
from the last couple of days below:
[2021-08-28T16:16:58-0500] [ALPM] upgraded cups-filters (1.28.9-1 -> 1.28.10-1)
[2021-08-28T16:16:58-0500] [ALPM] upgraded eos-apps-info (1.0.4-1 -> 1.0.6-1)
[2021-08-28T16:16:58-0500] [ALPM] upgraded eos-log-tool (1.4.8-1 -> 1.4.8-2)
[2021-08-28T16:16:58-0500] [ALPM] upgraded geoip-database (20210727-1 -> 20210824-1)
[2021-08-28T16:16:58-0500] [ALPM] upgraded glslang (11.5.0-1 -> 11.6.0-1)
[2021-08-28T16:16:58-0500] [ALPM] upgraded shaderc (2021.1-1 -> 2021.1-2)
[2021-08-28T16:16:58-0500] [ALPM] upgraded libplacebo (3.120.3-2 -> 3.120.3-3)
[2021-08-28T16:17:00-0500] [ALPM] upgraded linux-lts (5.10.60-1 -> 5.10.61-1)
[2021-08-28T16:17:03-0500] [ALPM] upgraded linux-lts-headers (5.10.60-1 -> 5.10.61-1)
[2021-08-28T16:17:03-0500] [ALPM] upgraded python-google-api-python-client (2.17.0-1 -> 2.18.0-1)
[2021-08-28T16:17:03-0500] [ALPM] upgraded python-kiwisolver (1.3.1-3 -> 1.3.2-1)
[2021-08-28T16:17:04-0500] [ALPM] upgraded xorg-xrdb (1.2.0-2 -> 1.2.1-1)
[2021-08-28T16:22:22-0500] [ALPM] upgraded bitwarden (1.28.1-1 -> 1.28.2-1)
[2021-08-28T16:22:28-0500] [ALPM] upgraded gwe (0.15.3-1 -> 0.15.4-1)
[2021-08-28T16:28:20-0500] [ALPM] upgraded popsicle-git (1.3.0.r43.g1a94779-1 -> 1.3.0.r44.gda43ab9-1)
[2021-08-28T19:04:45-0500] [ALPM] upgraded glances (3.2.1-1 -> 3.2.2-1)
[2021-08-28T19:04:45-0500] [ALPM] upgraded glib-networking (1:2.68.1-1 -> 1:2.68.2-1)
[2021-08-29T17:24:39-0500] [ALPM] upgraded qemu (6.0.0-3 -> 6.1.0-1)
[2021-08-30T10:43:32-0500] [ALPM] upgraded eos-bash-shared (1.9.8-1 -> 1.9.9-2)
[2021-08-30T21:50:06-0500] [ALPM] upgraded dkms (2.8.4-1 -> 2.8.5-1)
[2021-08-30T21:50:06-0500] [ALPM] upgraded imagemagick (7.1.0.4-2 -> 7.1.0.5-1)
[2021-08-30T21:50:06-0500] [ALPM] upgraded qt5-base (5.15.2+kde+r215-2 -> 5.15.2+kde+r222-1)
[2021-08-30T21:50:07-0500] [ALPM] upgraded qt5-declarative (5.15.2+kde+r29-1 -> 5.15.2+kde+r30-1)
[2021-08-31T10:54:46-0500] [ALPM] upgraded libgcrypt (1.9.3-1 -> 1.9.4-1)
[2021-08-31T10:54:46-0500] [ALPM] upgraded man-pages (5.12-2 -> 5.13-1)
[2021-08-31T10:54:46-0500] [ALPM] upgraded systemd-libs (249.3-1 -> 249.4-1)
[2021-08-31T10:54:46-0500] [ALPM] upgraded systemd (249.3-1 -> 249.4-1)
[2021-08-31T10:54:46-0500] [ALPM] upgraded systemd-sysvcompat (249.3-1 -> 249.4-1)
[2021-08-31T10:56:24-0500] [ALPM] upgraded timeshift (20.11.1+4+gd437358-1 -> 20.11.1+4+gd437358-3)
[2021-09-01T13:35:06-0500] [ALPM] upgraded aom (3.1.2-1 -> 3.1.2-2)
[2021-09-01T13:35:06-0500] [ALPM] upgraded avahi (0.8+20+gd1e71b3-1 -> 0.8+22+gfd482a7-1)
[2021-09-01T13:35:06-0500] [ALPM] upgraded freetype2 (2.10.4-1 -> 2.11.0-3)
[2021-09-01T13:35:07-0500] [ALPM] upgraded electron11 (11.4.12-1 -> 11.5.0-1)
[2021-09-01T13:35:07-0500] [ALPM] upgraded python-typing_extensions (3.10.0.0-1 -> 3.10.0.2-1)
[2021-09-01T13:35:07-0500] [ALPM] upgraded telegram-desktop (2.9.3-1 -> 3.0.0-1)
[2021-09-01T20:27:56-0500] [ALPM] upgraded re2 (1:20210801-1 -> 1:20210901-1)
[2021-09-02T04:51:20-0500] [ALPM] upgraded tzdata (2021a-1 -> 2021a-2)
[2021-09-02T04:51:20-0500] [ALPM] upgraded gpm (1.20.7.r38.ge82d1a6-3 -> 1.20.7.r38.ge82d1a6-4)
[2021-09-02T04:51:20-0500] [ALPM] upgraded iproute2 (5.13.0-1 -> 5.14.0-1)
[2021-09-02T04:51:26-0500] [ALPM] upgraded papirus-icon-theme (20210802-2 -> 20210901-1)
If it’s relevant at all, here is my output for grep -i installed /var/log/pacman.log
below for some of my most recently installed packages from the last couple of days:
[2021-08-12T22:41:11-0400] [ALPM] installed gwe (0.15.3-1)
[2021-08-16T14:43:12-0400] [ALPM] installed dracula-gtk-theme (v2.0-1)
[2021-08-16T17:24:21-0400] [ALPM] installed gtk-engine-murrine (0.98.2-4)
[2021-08-16T20:48:31-0400] [ALPM] installed yaru-sound-theme (21.10.1-1)
[2021-08-16T20:58:07-0400] [ALPM] installed yaru-gnome-shell-theme (21.10.1-1)
[2021-08-16T20:58:07-0400] [ALPM] installed yaru-session (21.10.1-1)
[2021-08-16T20:59:26-0400] [ALPM] installed libxpresent (1.0.0-2)
[2021-08-16T20:59:26-0400] [ALPM] installed metacity (3.40.0-1)
[2021-08-16T21:00:01-0400] [ALPM] installed yaru-metacity-theme (21.10.1-1)
[2021-08-16T21:01:43-0400] [ALPM] installed humanity-icon-theme (0.6.15-1)
[2021-08-16T21:02:11-0400] [ALPM] installed yaru-icon-theme (21.10.1-1)
[2021-08-16T21:03:22-0400] [ALPM] installed yaru-gtksourceview-theme (21.10.1-1)
[2021-08-16T21:04:28-0400] [ALPM] installed yaru-gtk-theme (21.10.1-1)
[2021-08-22T04:49:53-0500] [ALPM] warning: /etc/pacman.d/mirrorlist installed as /etc/pacman.d/mirrorlist.pacnew
[2021-08-27T10:24:28-0500] [ALPM] installed eos-apps-info (1.0.4-1)
[2021-08-29T17:24:39-0500] [ALPM] installed libbpf (0.4.0-1)
[2021-08-30T11:16:53-0500] [ALPM] installed exfatprogs (1.1.2-1)
[2021-08-31T10:54:46-0500] [ALPM] installed diffuse (0.6.0-1)
[2021-09-01T13:35:07-0500] [ALPM] installed rhythmbox (3.4.4-4)
[2021-09-01T13:42:47-0500] [ALPM] installed intltool (0.51.0-6)
[2021-09-01T13:42:47-0500] [ALPM] installed libkeybinder3 (0.3.2-3)
[2021-09-01T13:43:04-0500] [ALPM] installed rhythmbox-plugin-alternative-toolbar (0.19.3-1)
[2021-09-01T18:59:56-0500] [ALPM] installed yaru-metacity-theme-git (1:21.10.1.r33.ge5c308eda-1)
[2021-09-01T18:59:56-0500] [ALPM] installed yaru-unity-theme-git (1:21.10.1.r33.ge5c308eda-1)
[2021-09-01T18:59:56-0500] [ALPM] installed yaru-sound-theme-git (1:21.10.1.r33.ge5c308eda-1)
[2021-09-01T18:59:56-0500] [ALPM] installed yaru-gnome-shell-theme-git (1:21.10.1.r33.ge5c308eda-1)
[2021-09-01T18:59:56-0500] [ALPM] installed yaru-gtksourceview-theme-git (1:21.10.1.r33.ge5c308eda-1)
[2021-09-01T18:59:57-0500] [ALPM] installed yaru-icon-theme-git (1:21.10.1.r33.ge5c308eda-1)
[2021-09-01T18:59:57-0500] [ALPM] installed yaru-gtk-theme-git (1:21.10.1.r33.ge5c308eda-1)
[2021-09-01T18:59:57-0500] [ALPM] installed yaru-session-git (1:21.10.1.r33.ge5c308eda-1)
Finally, running pamac-manager
from the terminal and running Check Updates didn’t produce any error messages in a terminal so I didn’t bother to post that output. I suppose for the moment I am at an impasse! Now I don’t know if maybe perhaps pamac needs some rebuilds for things to function properly or if like I said perhaps it is just an issue on my end somehow. In any case, any insight, advice, or help would be most appreciated and if anyone else is experiencing this issue as well please let me know, thank you!
