Moved topic here as it was in the wrong category…
==> WARNING: PACKAGER should have the format ‘Example Name email@address.invalid’
==> Making package: pamac-aur-git 9.0.1.r9.g5cadbe2-1 (Wed 23 Oct 2019 03:51:54 PM PDT)
If it helps anyone, on my old Antergos system I just got a pacman update warning that breaks pamac…
I’m using KDE & LTS on this rig.
Now, checking my server running EndeavourOs KDE & LTS I get
package requires pacman<5.2 error
as well as ilmbase replace with openexr error
If I keep ilmbase upgrade fails…I’m going to leave it for now.
I have no idea if they are related, just saying…
as this is only the buildinstruction ( PKGBUILD )
you are the “packer” as you do building a package with yay
So the issue is on your side.
And everyone building this and do not have makepkg configured for a packer email.
But it is only a warning. And as you do not provide the package for others also no issue.
This is due the latest pacman update.
Yay was not updated, until a few hours ago, for pacman 5.2 I don’t know now …
ilbbase going to replace openexr, just say y on that one …thats no error…
pamac is current not compatible depend on upstream they fix it…shortest is removing pamac or just wait some days more…
And it seems to be working well, I have it now prebuilt in my own repos.
Well… Last yay is 9.4.2 on AUR with pacman 5.2 support included. About openexr? You have to accept this replacement.
