sudo pacman -Q works completely fine but -Qm just asks for a password and outputs absolutely nothing. I have a bunch of stuff installed and things I installed myself and I wanna remove some of those things like OSS because I installed the wrong one but it wont show me what I have installed
pacman {-Q --query}
For just querying pacman, there is no need for sudo.
On my end, pacman -Qm
works as expected.
-m, --foreign list installed packages not found in sync db(s) [filter]
Do you have any packages installed from outside the repos specified in /etc/pacman.conf?
Have a look at:
pacman -Q --help
for more options.
pacman -Q
shows you what you have installed.
pacman -Qm
shows you packages that are not currently in a repo
I am not sure either of those things really helps you with your goal.
I would install paclog and use paclog --action=install
and the read up from the bottom for packages you recently installed if I understand what you are trying to do.
This didn’t work for me but
paclog --action install
did.
Oops yeah, it should paclog --action=install
Seems to work both with and without =
Welcome to the forum!
Note that you don’t need sudo
in commands pacman -Q
or pacman -Qm
How exactly did you install them? Did you use pacman or yay, or something else?
