Packages not in aur
after disabling multilib in pacman.conf i get this when i run yay:
Pakete nicht im AUR: lib32-alsa-lib lib32-alsa-plugins lib32-audit lib32-brotli lib32-bzip2 lib32-curl lib32-dbus lib32-e2fsprogs lib32-expat lib32-fontconfig lib32-freetype2 lib32-glib2 lib32-harfbuzz lib32-icu lib32-json-c lib32-keyutils lib32-krb5 lib32-libcap lib32-libdrm lib32-libelf lib32-libffi lib32-libgcrypt lib32-libglvnd lib32-libgpg-error lib32-libidn2 lib32-libldap lib32-libnghttp2 lib32-libnghttp3 lib32-libnm lib32-libnsl lib32-libpciaccess lib32-libpipewire lib32-libpng lib32-libpsl lib32-libssh2 lib32-libtasn1 lib32-libtirpc lib32-libunistring lib32-libva lib32-libx11 lib32-libxau lib32-libxcb lib32-libxcrypt lib32-libxcrypt-compat lib32-libxdmcp lib32-libxext lib32-libxfixes lib32-libxinerama lib32-libxml2 lib32-libxshmfence lib32-libxss lib32-libxxf86vm lib32-llvm-libs lib32-lm_sensors lib32-mesa lib32-ncurses lib32-nspr lib32-nss lib32-nvidia-utils lib32-openssl lib32-p11-kit lib32-pam lib32-pcre2 lib32-pipewire lib32-spirv-tools lib32-sqlite lib32-systemd lib32-util-linux lib32-vulkan-icd-loader lib32-wayland lib32-xz lib32-zlib lib32-zstd steam
here my
pacman.conf
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
#CacheDir    = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
#HookDir     = /etc/pacman.d/hooks/
HoldPkg     = pacman glibc dracut kernel-install-for-dracut eos-dracut
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
Color
ILoveCandy
#NoProgressBar
CheckSpace
VerbosePkgLists
ParallelDownloads = 5
DownloadUser = alpm
#DisableSandbox
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Arch Linux
# packagers with `pacman-key --populate archlinux`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[endeavouros]
SigLevel = PackageRequired
Include = /etc/pacman.d/endeavouros-mirrorlist
#[core-testing]
#Include = /etc/pacman.d/mirrorlist
[core]
#[extra-testing]
[extra]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
#[multilib-testing]
#[multilib]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
what can I do to stop seeing the message?
Since you have disabled multilib, your package manager will assume that the may come from another source, AUR in this case. Since they are not in AUR, then you are getting this message.
You have a lot of packages installed from multilib.
Why are you disabling it if you have all those packages installed?
The short answer is “Remove all those packages from multilib”
Saw it disabled in a pacnew pacman.conf file. And wasn’t sure if 32 bit packages are installed. Now i know :slight_smile:
Thank you both for the clarification. i will enable it again.
Note that not all .pacnew files are good for simple merging in a local system.
/etc/pacman.conf is one of them.
And some other more dangerous examples are
/etc/passwd
/etc/group
/etc/shadow
because you might not be able to log in to your system if merging incorrectly.
So, don’t merge them blindly unless you know exactly what you are doing.
