Packages not in AUR: qcoro-qt6
Hello,
after today’s update there is this message
It looks like the package has been renamed from qcoro-qt6 to just qcoro.
There used to be separate -qt5 and -qt6 versions, but the -qt5 version has been dropped, so there’s no need to use the -qt6 designation anymore. Here’s the commit:
pacman (yay) should have asked you if you want to replace qcoro-qt6 with qcoro, and you answered the default Yes (as you should have), and now the package is just hanging around on your computer. Pacman doesn’t see it in the repos (because it’s been renamed), so it assumes it’s an AUR package.
You can delete it.
Hello, and thank you
today yay asked me to replace this file with qcoro
thanks again
