Hi,
i just installed EOS Ganymede on my laptop.
System works, but the package nvidia-inst NOT
i get command not found
Is it installed? Try sudo pacman -Syu nvidia-inst
Can you share the output of pacman -Q | grep nvidia. The drivers should be installed by default. In a hybrid laptop that output looks normal to me. You may not need nvidia-inst.
[peterz@Laptop ~]$ pacman -Q | grep nvidia
linux-firmware-nvidia 20260110-1
[peterz@Laptop ~]$
OK, you definitely don’t have the drivers, installed. Install nvidia-inst as @MyNameIsRichard suggested.
What makes you think you need Nvidia when your screenshot shows an Intel GPU?
it is aa hybrid intel/nvidia
also if it is an older one, the command should be executable
seems to be solved now, made a reboot
