I have set the package cleanup configuration to daily and it’s not working. I even checked “Remove uninstalled but still cached packages now” and it still doesn’t work. The package cache usage is currently 1.6 GB.
Edit: When I run paccache -r
it says “no candidate packages found for pruning”. So I guess there’s nothing to delete?
So, what is truth, and what is make-belief from your DE?
…seems make-belief… who or what is telling you, it’s 1.6GB?
…and did you reboot after deleting, and before checking again?
The package cleanup configuration is telling me. And yes, I rebooted after deleting and checking again.
The 1.6 GB might be because it keeps 3 package versions by default.
If I used pacman -Sc
it would probably delete it all.
pebcak
March 31, 2023, 7:47am
4
ArchStanton:
paccache -r
Yes, this command will, by default, retain the last three versions of the packages in the pacman cache.
ArchStanton:
pacman -Sc
This will remove packages that are no longer installed from the cache as well as currently unused sync databases.
For more info:
https://wiki.archlinux.org/title/Paccache#Cleaning_the_package_cache
Also: man paccache
and man pacman
manuel
March 31, 2023, 6:59pm
5
Delete uninstalled packages that are still cached:
sudo paccache -ruk0
Delete package cache but leave the latest package of each into the cache:
sudo paccache -rk1
Delete the whole package cache:
sudo rm -f /var/cache/pacman/pkg/*
A better way to do the same thing (smaller chance of screwing up):
sudo pacman -Scc
