Other OS not appearing in grub
Hi again!
I recently installed Gentoo on another drive but it isn’t appearing in EnOS grub.
os-prober shows:
/dev/nvme0n1p3:Gentoo Linux:Gentoo:linux
I have GRUB_DISABLE_OS_PROBER=false in my /etc/default/grub, and upon running grub-mkconfig -o /boot/grub/grub.cfg I get:
Generating grub configuration file ...
Found theme: /boot/grub/themes/EndeavourOS/theme.txt
Found linux image: /boot/vmlinuz-linux
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot:  intel-ucode.img initramfs-linux-fallback.img
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
Found Gentoo Linux on /dev/nvme0n1p3
Adding boot menu entry for UEFI Firmware Settings ...
done
However there is no menuentry for Gentoo in /boot/grub/grub.cfg and indeed won’t show up in grub.
I’m running out of ideas, I’d appreciate some help!
Have you tried reinstalling grub? sudo pacman -s grub
That could do it, I’ll try. Give me a moment.
Thanks for the suggestion, but Gentoo still isn’t showing up.
Maybe check this out.
https://bbs.archlinux.org/viewtopic.php?id=269769
Now it’s showing up, but displaying an error.
If I understood that correctly, I mounted my Gentoo partitions like so:
mount /dev/nvme0n1p3 /mnt/gentoo
mount /dev/nvme0n1p1 /mnt/gentoo/boot
And ran grub-mkconfig -o /boot/grub/grub.cfg once again.
Now, Gentoo has a menu entry! But when I enter it, I get a black screen with:
error: file '/boot/vmlinuz-5.15.75-gentoo-x86_64' not found.
error: you need to load the kernel first.
I’ll look into it later, but if anyone has any suggestion what to do, please share.
2022-11-22_11-06
says fixed when mounting the only gentoo boot partition under /mnt before running os-prober … so not what you have done mounting both
Oh, you’re totally right, my bad!
Did that, and now it’s working! Thank you so much :smiley:
¡Es un placer!
