OpenGL artifacts in 3D rendering
Hi, my specs are in one of the pictures provided, but as the title says, I’m getting artifacts in most any 3d rendering. Can anyone help?
https://cdn.discordapp.com/attachments/375444941905854464/836631482637221978/unknown.png https://i.imgur.com/H1uogQo.png https://cdn.discordapp.com/attachments/375444941905854464/836629777552375818/unknown.png
Do you have xf86-video-intel installed?
Yes
Did you try uninstalling it? Then you will run on the modesetting kernel driver.
Nothing changed.
Try using the following kernel parameter in the default grub command line in /etc/default/grub and regenerate a new grub file with sudo grub-mkconfig -o /boot/grub/grub.cfg
Add this kernel parameter
i915.enable_psr=0
Where in the file do I add that parameter?
Nevermind, I figured it out, and it worked! Thank you much, @ricklinux
Hey no problem! Sorry i didn’t get back to you sooner. Glad this worked.
