Official way to switch wm/twm?
hello i have gnome on my pc i do want to switch to sway.
but i want the official endeavour sway package, not the sway default one (stock)
in manjaro used to be a comand to do it officially for example if i was on i3 wm and switch to gnome after do it i should have gnome-manjaro with all manjaro bloat and not gnome-stock.
is out there something similar for endeavour ?
i dont want to re install the full os every time i want to try a twm/wm
The dotfiles are in a repository. I think you can install sway as regular, then get the dependencies and run setup.sh in this repo https://github.com/EndeavourOS-Community-Editions/sway
using tutorial inside the link @codic12 showing will install the same as you would get from ISO.
We do use it directly from GitHub.
