Odd resolution problem
Hey there people, i have a weird wee problem, I have installed Endeavour, and have had very few problems that i couldnt figure out with the help of reddit and these forums. However, i have a problem with setting my graphics resolution. I have a widescreen monitor, that supports a resolution up to 7680 X 2160, and that resolution seems to work fine, except everything is tiny, but when i try and change the resolution down to 5120 X 1440 the monitor just turns off, and then leaves with me with a black screen, i have tried to set this with both the built in display configuration and also with the nvidia X server settings, i dont know what else to try and or what commands / logs to post to help troubleshoot this, any help would be appreciated as i would like to use 5120 X 1440 resolution, cuz the 7280 X 2160 like i said makes everything very tiny.
Not sure what desktop environment you are using but in KDE you could try scaling, not too sure about others
Oh yes, i do use KDE, scaling seems like the easiest option :slight_smile:
Thanks !
You’re welcome, hope it helps
