Hello all,
Recently I installed EndeavourOS and I messed up the partitions a bit when I first installed it, which I only noticed after booting into the system post install. I rebooted my PC, going back into the installation USB, and went to redo the installation from scratch, properly separating my partitions this time.
I did the usual, setting up my partitions, however this time during the installation, the USB drive disconnected momentarily causing the installation to stop, and I had to redo it once more. It was at this attempt that I noticed that I wasn’t given an option to mount the boot to /boot/efi - in fact, there was no /boot/ option at all, only /efi - and while I thought it was strange for a moment, I proceeded and finished the installation anyway.
The next time I booted up my PC, I noticed that I had “two” separate installations of EndeavourOS in the systemd boot menu, which I found rather weird, considering how I chose the option to wipe the contents of my HDD. I didn’t think much of it and continued on using my computer as usual. However, just earlier, I decided to check out what that other (or rather, previous) installation of EOS is, and it seemed like it wanted to boot just fine, but then it got stuck trying to load something (I forgot exactly what, it had an unlimited time span worth of attempts), so I force shut down my PC, and when I booted it back on, it skipped the boot menu completely, going into my current EOS installation.
I hope this isn’t any issue, since my computer boots and runs fine. Here I also have the results of running lsblk:
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 931,5G 0 disk
├─sda1 8:1 0 19,5G 0 part /
├─sda2 8:2 0 19,5G 0 part /usr
├─sda3 8:3 0 19,5G 0 part /var
├─sda4 8:4 0 872,3G 0 part /home
└─sda5 8:5 0 600M 0 part /efi
sdb 8:16 0 223,6G 0 disk
├─sdb1 8:17 0 16M 0 part
└─sdb2 8:18 0 223,6G 0 part
Where sda is the current EOS, and sdb is a Windows 11 SSD (which I will get to in a moment). I know that I should have a /boot/ mount point, where /efi would sit (which was the case in the first installation of EOS), but if this current setup doesn’t change much, then I suppose no harm will be done. Additionally, /boot/ exists, and this is the only thing inside:
sudo ls /boot
intel-ucode.img
My only thought here if I am to move /efi back into /boot/, is to do it through a live bootable USB and go from there, though I’m unsure how without reinstalling my entire OS just to accommodate for that. On that note, I’m unsure how to get the boot menu to show up again, since I would like to be able to use Windows as well.
Now, as for Windows, I’m rather confused as to why I am no longer able to boot into it (after the first install of EOS). The OS is on the SSD, but I simply cannot boot into it. Here’s what happens when I run efibootmgr:
sudo efibootmgr
BootCurrent: 0002
Timeout: 1 seconds
BootOrder: 0002,0007,0005,0006,0008,000A,0009,0004
Boot0002* Linux Boot Manager HD(5,GPT,350e50d2-8c73-4970-ae10-5d7f892ae6e7,0x800,0x12c000)/\EFI\SYSTEMD\SYSTEMD-BOOTX64.EFI
Boot0004* Windows Boot Manager VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000000000100000010000000040000007fff0400
Boot0005* WDC WD10EZEX-00WN4A0 BBS(HD,,0x0)0000424f
Boot0006* KINGSTON SA400S37240G BBS(HD,,0x0)0000424f
Boot0007* UEFI OS HD(5,GPT,350e50d2-8c73-4970-ae10-5d7f892ae6e7,0x800,0x12c000)/\EFI\BOOT\BOOTX64.EFI0000424f
Boot0008* WD Elements 2621 1026 BBS(HD,,0x0)0000424f
Boot0009* UEFI: IS817 innostor, Partition 1 PciRoot(0x0)/Pci(0x14,0x0)/USB(8,0)/HD(1,GPT,66d5975c-cc3a-473e-aa85-0d5e2ff8a76a,0x800,0xefffd8)0000424f
Boot000A* IS817 innostor BBS(HD,,0x0)0000424f
Note that I have no clue why it shows multiples of the same thing, but I dare not touch them lest I somehow brick my PC. Could the installation of EOS have wiped the Windows boot? If a simple reinstall of Windows will fix this, then it’s fine by me, I had no intention of keeping Windows 11 on my system any longer, I will go down to 10.
So, to sum it up, my /efi isn’t mounted to /boot/, but doesn’t seem to pose a problem, and installing EOS removed my ability to boot into Windows.
