Nvidia drivers won't load after installation
on using
inxi -G
  Device-1: Intel Alder Lake-P Integrated Graphics driver: i915 v: kernel
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] driver: N/A
  Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera
    type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: intel
    unloaded: modesetting gpu: i915 resolution: 1920x1080~144Hz
  OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 22.1.2
you can see that there is N/A following my Device-2 which is my Nvidia GPU.
I have tried installing drivers using
sudo nvidia-installer-dkms
it was successful, but still the drivers are not available.
Please help me sort out this problem.
More info on my machine
  Kernel: 5.18.7-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 wm: xfwm dm: LightDM
  Type: Laptop System: HP product: OMEN by HP Laptop 16-b1xxx v: N/A
  Mobo: HP model: 8A13 v: 32.19 serial: <superuser required> UEFI: AMI
    v: F.05 date: 03/10/2022
Battery:
  ID-1: BAT0 charge: 79.0 Wh (100.0%) condition: 79.0/83.0 Wh (95.2%)
    volts: 13.0 min: 11.6 model: HP Primary serial: <filter> status: full
  Info: 14-core (6-mt/8-st) model: 12th Gen Intel Core i7-12700H bits: 64
    type: MST AMCP arch: Alder Lake rev: 3 cache: L1: 1.2 MiB L2: 11.5 MiB
    L3: 24 MiB
  Speed (MHz): avg: 610 high: 813 min/max: 400/4679:4700:3500 cores: 1: 803
    2: 595 3: 449 4: 398 5: 561 6: 813 7: 454 8: 599 9: 804 10: 776 11: 697
    12: 566 13: 754 14: 596 15: 800 16: 527 17: 553 18: 423 19: 620 20: 420
    bogomips: 107560
  Device-1: Intel Alder Lake-P Integrated Graphics vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen12.2 ports: active: eDP-1 empty: DP-1,DP-2
    bus-ID: 00:02.0 chip-ID: 8086:46a6
    vendor: Hewlett-Packard driver: N/A arch: Ampere pcie: speed: 16 GT/s
    lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:2520
    type: USB driver: uvcvideo bus-ID: 3-6:2 chip-ID: 05c8:0b04
  Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver:
    X: loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96
  Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x0aae res: 1920x1080
    dpi: 135 diag: 407mm (16")
    direct render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio
    vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3
    chip-ID: 8086:51c8
  Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    pcie: speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:228e
  Sound Server-1: ALSA v: k5.18.7-arch1-1 running: yes
  Sound Server-2: PulseAudio v: 16.1 running: no
  Sound Server-3: PipeWire v: 0.3.52 running: yes
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 2e:00.0 chip-ID: 10ec:8168
  IF: eno1 state: down mac: <filter>
Bluetooth:
  Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:3
    chip-ID: 8087:0033
  Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
  Local Storage: total: 953.87 GiB used: 256.73 GiB (26.9%)
  ID-1: /dev/nvme0n1 vendor: Western Digital
    model: WD PC SN810 SDCPNRY-1T00-1006 size: 953.87 GiB speed: 63.2 Gb/s
    lanes: 4 serial: <filter> temp: 39.9 C
There is currently a problem with Nvidia drivers and intel users on Kernel 5.18. Try adding ibt=off as kernel parameter. Github
Thank you so much its working now:).
hi @yasho and @Akix3,
welcome to the purple universe :enos: :enos_flag: :penguin_face: :rocketa_purple:
Glad to hear that it’s working now!
And thanks a lot @pycrk :slightly_smiling_face: :enos:
