I installed Endeavour OS with Nvidia-Driver option. My laptop has two gpus: integrated and Nvidia gpu. But I have a problem. When I try to use my Nvidia gpu with optimus manager it errors.
Well, you are receiving a message that tells you that wayland isn’t supported and it will fail if you continue. Then you hit “yes” and it fails.
If you want to use optimus manager, you may want to consider switching from wayland to x11. On the login screen, there should be an option to choose an X11 session.
