packages will not differ on booting different kernels
But as you are using dkms version it will build modules for every installed kernel… so it could be it does currently not work on zen to build the module-- or it is not working when booting zen … you could check the output when of building modules when reinstalling it:
sudo pacman -S linux-zen and check the output to see if it may give error on building nvidia modules
I reinstall linux-zen check nvidia and no issue
I reboot on linux-zen and my sceen is blocked with this information
but you do not check the exact output of building modules… this would be what you should have shared here
ok
how can i do to display this information, i’m sorry but i m not an expert with command lines
PS: i boot on lts kernel
you can copy paste from the terminal output … and post here in code tags
sorry which command i have to put on terminal
I’m sorry, I feel like I’m wasting your time.
and I think my explanation does not help you
[foxy1686@foxy1686-ms7d32 ~]$ pacman -Qs nvidia
local/egl-wayland 2:1.1.11-2
EGLStream-based Wayland external platform
local/libvdpau 1.5-1
Nvidia VDPAU library
local/libxnvctrl 525.60.11-2
NVIDIA NV-CONTROL X extension
local/nvidia-dkms 525.60.11-1
NVIDIA drivers - module sources
local/nvidia-hook 1.2-1
pacman hook for nvidia
local/nvidia-inst 1.8-1
Script to setup nvidia drivers (dkms version) in EndeavourOS
local/nvidia-installer-common 1.7-2
Common scripts for nvidia-installer-dkms and nvidia-inst
local/nvidia-settings 525.60.11-2
Tool for configuring the NVIDIA graphics driver
local/nvidia-utils 525.60.11-1
from reinstalling zen:
dkms status could give some info too about installed modules…
:: Pre-transaction-Hooks started…
(1/1) Remove upgraded DKMS modules
==> dkms remove --no-depmod vboxhost/7.0.4_OSE -k 6.1.2-zen1-1-zen
(3/6) Install DKMS modules
==> dkms install --no-depmod vboxhost/7.0.4_OSE -k 6.1.2-zen1-1-zen
==> depmod 6.1.2-zen1-1-zen
this is not for nvidia module but it should show similar if it was running fine…
[foxy1686@foxy1686-ms7d32 ~]$ dkms status
nvidia/525.60.11, 5.15.86-1-lts, x86_64: installed
nvidia/525.60.11, 6.1.2-arch1-1, x86_64: installed
nvidia/525.60.11, 6.1.2-zen1-1-zen, x86_64: installed
does not look like ut fails to build modules for zen… but it i see others have the same issue with Nvidia and zen Kernel currently
yes i saw on various forum that there is a problem with the zen kernel.
well i think i will stay with lts and wait maybe new update for zen kerne
or change to AMD graphic card
thanks so much to have tried to help me
we have a nice community
What’s wrong with using the current kernel?
