NVIDIA boot entry on ISO questions
So, when booting the ISO from a USB drive, I see 2 options for installing EndeavourOS: the Normal live environment and an NVIDIA one that says to use for latest NVIDIA cards only. A few questions regarding these choices:
  1. What is the difference between the normal entry and the NVIDIA one? Is it the packages they install?
  2. If I have an RTX card like an RTX 3060, should I choose the NVIDIA option for installing EndeavourOS instead of the regular one?
It both loads the nvidia drivers into the live session and installs them.
If you choose the normal option, you will noveau drivers which will be very slow for your hardware.
Yes, 20-series and newer desktop cards. Technically any Turing or newer cards so also the 16xx cards.
Alright, thank you!
