After a kernel update I get following output
(5/6) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'default'
-> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
==> Starting build: 5.9.2-arch1-1
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [encrypt]
-> Running build hook: [lvm2]
-> Running build hook: [resume]
-> Running build hook: [filesystems]
-> Running build hook: [fsck]
==> Generating module dependencies
==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'fallback'
-> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: wd719x
==> WARNING: Possibly missing firmware for module: aic94xx
==> Creating gzip-compressed initcpio image: /boot/initramfs-linux-fallback.img
(6/6) Inform user to reboot after certain system package upgrades.
Is there a way to generate a notification on the desktop for the reboot?
Christoph
manuel
October 30, 2020, 4:17pm
2
That text is an indication that you have a pacman hook (/etc/pacman.d/hooks/eos-reboot-required.hook) from eos-update-notifier in use.
If eos-update-notifier is correctly installed, you should have a program
/usr/bin/eos-reboot-required available, and that should give you a system notification after kernel updates.
If all the above is in order, the system notification may not be working. Which DE are you using?
I’m on GNOME.
Just checked this, and indeed by running this I get a message. Is there a way to check why I did not get this message after the upgrade?
manuel
October 30, 2020, 4:26pm
4
And you are not using TTY when updating? Just making sure…
I’m on the desktop using guake and sudo pacman -Syu
Would it be possible to a line like this
Target = *
to /etc/pacman.d/hooks/eos-reboot-required.hook
in order to get a message on a random update?
manuel
October 30, 2020, 4:33pm
6
Yes, for testing that is OK.
Alternatively, some single package like
Target = xed
would not cause many notifications when it works.
The you could simply reinstall xed and see what happens:
sudo pacman -S xed
Hmmm I tried with
Target = code
and sudo pacman -S code
but I only get the message
Edit: I tried again as su
and it worked then!
Edit 2: But I get three messages.
manuel
October 30, 2020, 4:42pm
8
I probably need to install Gnome and see if it works here.
Anyway, this is a source of more information: https://wiki.archlinux.org/index.php/Desktop_notifications
manuel
October 30, 2020, 4:51pm
9
Interesting results!
Just to check something: what does command
users
show?
csteinforth csteinforth csteinforth
Seems I am logged in more than once?!
Hmm but why? I just rebooted, and logged in via gdm.
Edit: Found the reason. When I disable the autostart in guake there is only one of me…
manuel
October 30, 2020, 4:59pm
13
Just finished installing EndeavourOS with Gnome.
Command users
gives only one manuel
Edit: OK, great that the reason was found.
manuel
October 30, 2020, 5:30pm
14
Looks like it is only related to su vs. sudo!
I’ll have to find a solution, but please don’t hold your breath…
So, as you said, it works with
su -c ...
but not with
sudo ...
There seems to be a long standing bug in guake which starts a new session for every new tab.
manuel
October 30, 2020, 6:37pm
16
So far I haven’t found a solution to the su/sudo issue.
As a workaround, you might want to modify the config file /etc/eos-update-notifier.conf :
ShowHowAboutUpdates=window
Then it will show you a window (not a notification though) about updates, and if you click Update , it will allow you to update the system.
