No WiFi in live environment. Try to fix or don't bother?
Hi, I’m new to EndeavourOS.
I tried to install it today, but when the DE loaded, a dialog box popped up saying that internet connection is not available, and I could either do an offline install or go to network manager. Should I bother trying to fix it, or the Wi-Fi will work after the offline installation just fine?
Here’s some information:
  • I dual boot with Windows 10, Fast Boot is OFF.
  • My Wireless adapter is Intel Wireless-AC 9260.
  • lspci -k says I’m using iwlwifi kernel driver.
Thank you in advance.
Could you enter your wifi-password in the network manager?
The thing is, there’s no WiFi connections in network manager at all.
Okay nevermind, I thought the available wifi connections was meant to show in network manager, so I ignored the wifi icon on the taskbar, but it was there all along :sweat_smile: Forget I asked.
