Hello!
I recently updated my system(cpu and motherboard) and now, on freshly installed EndeavourOs(everything works fine on windows 11), my audio input doesn’t register any sound from microphone, but register every sound on my pc. So my companions hear themselfs and my music instead of me.
I have researched this issue for some time and only similar problem I have found is this topic on garuda linux forum. It looks very similar(I updated to asus b650-e motherboard, btw), but it doesn’t have any solution.
I tried to switch between pipewire and pulseaudio, unmute all devices in alsamixer, switching configurations in pulseaudiom, but no success
inxi -Fazy
Kernel: 6.1.11-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: initrd=\ae7cce56dfb0432c8935cd2717eea48d\6.1.11-arch1-1\initrd
nvme_load=YES rw root=UUID=926bf9dc-ddd9-45dc-9116-75a89d923b03
systemd.machine_id=ae7cce56dfb0432c8935cd2717eea48d
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Mobo: ASUSTeK model: ROG STRIX B650E-I GAMING WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0821
date: 11/15/2022
Battery:
Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 9 7950X bits: 64 type: MT MCP arch: Zen 4 gen: 5
level: v4 note: check built: 2022 process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3321 high: 5739 min/max: 3000/5880 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4500 2: 3000
3: 3000 4: 4500 5: 3000 6: 3000 7: 3000 8: 4500 9: 3000 10: 3000 11: 3000
12: 2801 13: 2808 14: 3000 15: 4905 16: 3000 17: 3000 18: 3000 19: 3000
20: 3000 21: 3000 22: 5739 23: 3000 24: 3175 25: 3000 26: 3000 27: 2874
28: 3000 29: 3000 30: 3000 31: 4500 32: 3000 bogomips: 287552
Vulnerabilities:
prctl
sanitization
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate] vendor: Gigabyte
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2488
class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1,HDMI-A-1
bus-ID: 0c:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 50.0 C
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,radeon alternate: fbdev,nouveau,nv,vesa dri: radeonsi
gpu: nvidia,amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-0 res: 2560x1440 hz: 144 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce RTX
3070/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 1-6:2 pcie: chip-ID: 0b05:1a5c
class-ID: 0300 gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 0c:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: ASUSTek USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k6.1.11-arch1-1 running: yes
Sound Server-2: PipeWire v: 0.3.65 running: yes
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 08:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 09:00.0 chip-ID: 14c3:0616 class-ID: 0280
Bluetooth:
Device-1: Foxconn / Hon Hai Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-11:5 chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
Local Storage: total: 931.51 GiB used: 28.33 GiB (3.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 46.9 C scheme: GPT
ID-1: / raw-size: 292.47 GiB size: 286.82 GiB (98.07%) used: 27.85 GiB (9.7%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 54.4 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): N/A
Processes: 498 Uptime: 7m wakeups: 2 Memory: 61.96 GiB used: 5.29 GiB (8.5%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 Packages: pm: pacman pkgs: 983 libs: 271 tools: paru,yay
Shell: Zsh v: 5.9 running-in: kgx inxi: 3.3.25
pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 320
Tile Size: 65472
User Name: mikluha
Host Name: mikluha-pc
Server Name: PulseAudio (on PipeWire 0.3.65)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.usb-Generic_USB_Audio-00.analog-stereo
Default Source: alsa_input.usb-Generic_USB_Audio-00.analog-stereo
Cookie: cbbd:e1e7
arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
Subdevices: 7/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
Subdevices: 8/8
card 3: Audio [USB Audio], device 0: USB Audio [USB Audio]
Subdevices: 0/1
card 3: Audio [USB Audio], device 1: USB Audio [USB Audio #1]
Subdevices: 1/1
card 3: Audio [USB Audio], device 2: USB Audio [USB Audio #2]
Subdevices: 1/1
wpctl status
PipeWire 'pipewire-0' [0.3.65, mikluha@mikluha-pc, cookie:3418218983]
└─ Clients:
31. pipewire [0.3.65, mikluha@mikluha-pc, pid:1530]
32. WirePlumber [0.3.65, mikluha@mikluha-pc, pid:1529]
33. WirePlumber [export] [0.3.65, mikluha@mikluha-pc, pid:1529]
53. GNOME Volume Control Media Keys [0.3.65, mikluha@mikluha-pc, pid:1632]
54. GNOME Shell Volume Control [0.3.65, mikluha@mikluha-pc, pid:1474]
55. xdg-desktop-portal [0.3.65, mikluha@mikluha-pc, pid:1885]
65. Mutter [0.3.65, mikluha@mikluha-pc, pid:1474]
66. spotify [0.3.65, mikluha@mikluha-pc, pid:2718]
72. telegram-desktop [0.3.65, mikluha@mikluha-pc, pid:3483]
73. helvum [0.3.65, mikluha@mikluha-pc, pid:4565]
74. easyeffects [0.3.65, mikluha@mikluha-pc, pid:3819]
109. Chromium input [0.3.65, mikluha@mikluha-pc, pid:4077]
110. WEBRTC VoiceEngine [0.3.65, mikluha@mikluha-pc, pid:4036]
111. PulseAudio Volume Control [0.3.65, mikluha@mikluha-pc, pid:6793]
176. Google Chrome input [0.3.65, mikluha@mikluha-pc, pid:7333]
177. wpctl [0.3.65, mikluha@mikluha-pc, pid:9790]
Audio
├─ Devices:
│ 41. GA104 High Definition Audio Controller [alsa]
│ 42. Rembrandt Radeon High Definition Audio Controller [alsa]
│ 43. Built-in Audio [alsa]
│ 56. USB Audio [alsa]
├─ Sinks:
│ 50. Built-in Audio Analog Stereo [vol: 0.15]
│ * 57. USB Audio Analog Stereo [vol: 0.56]
│ 75. Easy Effects Sink [vol: 1.00]
├─ Sink endpoints:
├─ Sources:
│ 51. Built-in Audio Analog Stereo [vol: 1.00]
│ * 58. USB Audio Analog Stereo [vol: 1.00]
│ 76. Easy Effects Source [vol: 1.00]
├─ Source endpoints:
└─ Streams:
67. spotify
68. output_FL > Easy Effects Sink:playback_FL [active]
69. output_FR > Easy Effects Sink:playback_FR [active]
112. PulseAudio Volume Control
106. input_FR < Loopback PCM:monitor_FR [active]
108. monitor_FL
120. monitor_FR
131. input_FL < Loopback PCM:monitor_FL [active]
113. PulseAudio Volume Control
134. monitor_FR
135. input_FR < USB Audio:monitor_FR [active]
136. monitor_FL
137. input_FL < USB Audio:monitor_FL [active]
121. PulseAudio Volume Control
140. input_FL < USB Audio:capture_FL [active]
141. monitor_FL
142. input_FR < USB Audio:capture_FR [active]
143. monitor_FR
122. WEBRTC VoiceEngine
124. monitor_FL
125. input_FR < USB Audio:capture_FR [active]
128. input_FL < USB Audio:capture_FL [active]
172. monitor_FR
129. PulseAudio Volume Control
105. monitor_FL
107. input_FL < Loopback PCM:capture_FL [active]
138. monitor_FR
139. input_FR < Loopback PCM:capture_FR [active]
130. PulseAudio Volume Control
148. input_FL < Easy Effects Source:capture_FL [active]
149. monitor_FL
150. input_FR < Easy Effects Source:capture_FR [active]
151. monitor_FR
132. PulseAudio Volume Control
144. input_FL < Easy Effects Sink:monitor_FL [active]
145. monitor_FL
146. input_FR < Easy Effects Sink:monitor_FR [active]
147. monitor_FR
133. PulseAudio Volume Control
152. input_FL < spotify:output_FL [active]
153. monitor_FL
154. input_FR < spotify:output_FR [active]
155. monitor_FR
Video
├─ Devices:
│ 40. Droidcam [v4l2]
├─ Sinks:
├─ Sink endpoints:
├─ Sources:
│ * 44. Droidcam (V4L2)
└─ Streams:
Settings
└─ Default Configured Node Names:
0. Audio/Sink alsa_output.usb-Generic_USB_Audio-00.analog-stereo.5
1. Audio/Source alsa_input.usb-Generic_USB_Audio-00.pro-input-2
Any help or advice is appreciated, thank you!
