Ok, i will try the LTS kernel…
Also, I suspended my session again and same issue with no sound. I then went into alsamixer and noticed my FRONT speakers/volume was muted. I unmuted and I get the crackling/buzzzing sound. Then if I go into Audio Settings and change Profile to something else and back to default, the sound works.
Very weird!
Is there a way to save alsamixer settings to always have the FRONT speaker/volume unmuted at all times?
All I do now, is basically googling the problem as I kind of ran out of ideas, sorry.
In the Arch forum from 2021 I found the same issue and there the problem was linked to alsa and a downgrade of alsa solved it. But that also is not a permanent solution…
In case I read or experience something promising, I will let you know. And maybe someone else here in the forum will post a suitable solution, who knows.
Hello again,
this thread from the Manjaro forum made me think that you should also check the status of the pipewire-systemd-service after suspend, when you have the problem: https://forum.manjaro.org/t/no-audio-after-suspend/78472/2
Hi Pig,
So, I switched DE’s to Gnome and sound was much better. Been working for about month until I ran latest updates this morning. Now I have no sound. I might be using wireplumber instead of pipewire. How do I confirm that?
