Ok, here’s the journalctl results:
They say it’s not convenient to downgrade to that kernel for being older, should I?
Feb 12 09:07:52 jaime-pc kernel: sof-audio-pci 0000:00:1f.3: Direct firmware load for intel/sof/sof-cfl.ri failed with error -2
Feb 12 09:07:52 jaime-pc kernel: sof-audio-pci 0000:00:1f.3: error: request firmware intel/sof/sof-cfl.ri failed err: -2
Feb 12 09:07:52 jaime-pc kernel: sof-audio-pci 0000:00:1f.3: error: failed to load DSP firmware -2
Feb 12 09:07:52 jaime-pc kernel: sof-audio-pci 0000:00:1f.3: error: sof_probe_work failed err: -2
more hands more ideas more help more fun
downgrading the kernel is not a solution on archbased… you could try LTS kernel… but it is changed also to a more new one lately …
If you do install the linux-lts
kernel it should be 5.4 as opposed to 5.5 that you have installed now. That changed recently from linux-lts 4.19 to linux-lts 5.4. Do you need help to install it?
Site says unreachable.
may try this firmware package and reboot after install:
sudo pacman -S sof-firmware
it seems a known bug with your audio chipset…
OMG, it finally worked, sorry for the late response but the forum rules are hard with newbies
Thank you so much for your help @BONK @joekamprad @ricklinux.
I now have a problem with Nvidia drivers and dual display with HDMI, but will open a new post.
Please do and glad you got it sorted. From the output you provided I see you used the free drivers. You have an nvidia device and should use the non free drivers. But that’s for another thread.
I just want to confirm that I also had the problem that my soundcard chipset (chip ID: 10de:10fa) also could not be found. The problem was solved with @joekamprad solution of updating the firmware.
Thanks
This saved me today! Thanks <3
@joekamprad this got my bluetooth speaker working but there’s still a minor issue of the headphone jack on the case not working (works with other OSes) even though pulse shows the sound as receiving sound.
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
card 2: Audio [USB Audio], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 2: Audio [USB Audio], device 1: USB Audio [USB Audio #1]
Subdevices: 1/1
card 2: Audio [USB Audio], device 2: USB Audio [USB Audio #2]
Subdevices: 1/1
card 2: Audio [USB Audio], device 3: USB Audio [USB Audio #3]
Subdevices: 1/1
Any ideas?
Here’s hardware info:
H/W path Device Class Description
system MS-7D54 (To be filled by O.E.M.)
/0 bus MAG X570S TOMAHAWK MAX WIFI (MS-7D54)
/0/0 memory 64KiB BIOS
/0/11 memory 64GiB System Memory
/0/11/0 memory 2133 MHz (0,5 ns) [empty]
/0/11/1 memory 32GiB DIMM DDR4 Synchronous Unbuffered (Unregistered) 2133 MHz (0,5 ns)
/0/11/2 memory 2133 MHz (0,5 ns) [empty]
/0/11/3 memory 32GiB DIMM DDR4 Synchronous Unbuffered (Unregistered) 2133 MHz (0,5 ns)
/0/14 memory 768KiB L1 cache
/0/15 memory 6MiB L2 cache
/0/16 memory 64MiB L3 cache
/0/17 processor AMD Ryzen 9 5900X 12-Core Processor
/0/100 bridge Starship/Matisse Root Complex
/0/100/0.2 generic Starship/Matisse IOMMU
/0/100/1.1 bridge Starship/Matisse GPP Bridge
/0/100/1.1/0 /dev/nvme0 storage Samsung SSD 980 PRO 1TB
/0/100/1.1/0/0 hwmon0 disk NVMe disk
/0/100/1.1/0/2 /dev/ng0n1 disk NVMe disk
/0/100/1.1/0/1 /dev/nvme0n1 disk 1TB NVMe disk
/0/100/1.1/0/1/1 volume 99MiB Windows FAT volume
/0/100/1.1/0/1/2 /dev/nvme0n1p2 volume 15MiB reserved partition
/0/100/1.1/0/1/3 /dev/nvme0n1p3 volume 735GiB Windows NTFS volume
/0/100/1.1/0/1/4 /dev/nvme0n1p4 volume 508MiB Windows NTFS volume
/0/100/1.1/0/1/5 /dev/nvme0n1p5 volume 195GiB EXT4 volume
/0/100/1.2 bridge Starship/Matisse GPP Bridge
/0/100/1.2/0 bridge Matisse Switch Upstream
/0/100/1.2/0/4 bridge Matisse PCIe GPP Bridge
/0/100/1.2/0/4/0 enp38s0 network RTL8125 2.5GbE Controller
/0/100/1.2/0/6 bridge Matisse PCIe GPP Bridge
/0/100/1.2/0/6/0 wlan0 network Wi-Fi 6 AX210/AX211/AX411 160MHz
/0/100/1.2/0/8 bridge Matisse PCIe GPP Bridge
/0/100/1.2/0/8/0 generic Starship/Matisse Reserved SPP
/0/100/1.2/0/8/0.1 bus Matisse USB 3.0 Host Controller
/0/100/1.2/0/8/0.1/0 usb1 bus xHCI Host Controller
/0/100/1.2/0/8/0.1/0/4 communication Bluetooth wireless interface
/0/100/1.2/0/8/0.1/0/6 bus USB2.0 Hub
/0/100/1.2/0/8/0.1/0/6/2 input MYSTIC LIGHT
/0/100/1.2/0/8/0.1/1 usb2 bus xHCI Host Controller
/0/100/1.2/0/8/0.3 bus Matisse USB 3.0 Host Controller
/0/100/1.2/0/8/0.3/0 usb3 bus xHCI Host Controller
/0/100/1.2/0/8/0.3/0/5 multimedia USB Audio
/0/100/1.2/0/8/0.3/0/6 bus USB2.0 Hub
/0/100/1.2/0/8/0.3/1 usb4 bus xHCI Host Controller
/0/100/1.2/0/9 bridge Matisse PCIe GPP Bridge
/0/100/1.2/0/9/0 storage FCH SATA Controller [AHCI mode]
/0/100/1.2/0/a bridge Matisse PCIe GPP Bridge
/0/100/1.2/0/a/0 storage FCH SATA Controller [AHCI mode]
/0/100/3.1 bridge Starship/Matisse GPP Bridge
/0/100/3.1/0 display NVIDIA Corporation
/0/100/3.1/0.1 multimedia GA102 High Definition Audio Controller
/0/100/7.1 bridge Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
/0/100/7.1/0 generic Starship/Matisse PCIe Dummy Function
/0/100/8.1 bridge Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
/0/100/8.1/0 generic Starship/Matisse Reserved SPP
/0/100/8.1/0.1 generic Starship/Matisse Cryptographic Coprocessor PSPCPP
/0/100/8.1/0.3 bus Matisse USB 3.0 Host Controller
/0/100/8.1/0.3/0 usb5 bus xHCI Host Controller
/0/100/8.1/0.3/0/4 input USB Receiver
/0/100/8.1/0.3/1 usb6 bus xHCI Host Controller
/0/100/8.1/0.4 multimedia Starship/Matisse HD Audio Controller
/0/100/14 bus FCH SMBus Controller
/0/100/14.3 bridge FCH LPC Bridge
/0/101 bridge Starship/Matisse PCIe Dummy Host Bridge
/0/102 bridge Starship/Matisse PCIe Dummy Host Bridge
/0/103 bridge Starship/Matisse PCIe Dummy Host Bridge
/0/104 bridge Starship/Matisse PCIe Dummy Host Bridge
/0/105 bridge Starship/Matisse PCIe Dummy Host Bridge
/0/106 bridge Starship/Matisse PCIe Dummy Host Bridge
/0/107 bridge Starship/Matisse PCIe Dummy Host Bridge
/0/108 bridge Matisse Device 24: Function 0
/0/109 bridge Matisse Device 24: Function 1
/0/10a bridge Matisse Device 24: Function 2
/0/10b bridge Matisse Device 24: Function 3
/0/10c bridge Matisse Device 24: Function 4
/0/10d bridge Matisse Device 24: Function 5
/0/10e bridge Matisse Device 24: Function 6
/0/10f bridge Matisse Device 24: Function 7
/0/1 system System Board
/0/2 system Motherboard registers
/0/3 system AT Real-Time Clock
/0/4 system Motherboard registers
/0/5 communication 16550A-compatible COM port
/0/6 system Motherboard registers
could you open a new thread?
This one is 10 months old and solved.
–closing–
