hi guys
after the last update the result of sudo journalctl -p 3 -xb is this: pw.module: No module “libpipewire-module-x11-bell” was found
Has anyone else had the same result?
is it a bug or does it need to be fixed?
Eos latest version mate-desktop
ivanhoe
November 15, 2022, 9:57pm
2
pebcak
November 15, 2022, 10:03pm
3
I have also the same:
Doesn’t seem to be a bug. The module is provided by:
$ pacman -Si pipewire-x11-bell
Repository : extra
Version : 1:0.3.60-1
Description : Low-latency audio/video router and processor - X11 bell
Architecture : x86_64
URL : https://pipewire.org
Licenses : MIT
Groups : None
Provides : None
Depends On : libcanberra.so=0-64 libpipewire-0.3.so=0-64 libx11 libxfixes pipewire
Optional Deps : None
Conflicts With : None
Replaces : None
Download Size : 9.33 KiB
Installed Size : 19.10 KiB
Packager : Jan Alexander Steffens (heftig) <heftig@archlinux.org>
Build Date : Thu 10 Nov 2022 05:41:12 PM CET
Validated By : MD5 Sum SHA-256 Sum Signature
So as mentioned above, if you don’t need it, I guess you could ignore it.
‘No module “libpipewire-module-x11-bell” was found’
my audio works regularly as before
whether I need it I don’t know, I don’t think I need it if as I said my audio works
Before, with sudo journalctl -p 3 -xb I never had such a negative response!
only with yesterday’s update I noticed this and wanted to understand more!
If you tell me it is a bug then I will ignore it
ivanhoe
November 15, 2022, 10:10pm
6
The whole pipewire-architecture is still a work in progress. Maybe, at a later date (perhaps) the error message will disappear again.
ok!
thank you, and hope it will be solved!
