No home wifi. it worked on ubuntu. only mobile hotspot works
https://streamable.com/whqvxz It didn’t work on plasma 5 i tried 6 nothing
Network controller: Intel Corporation Wi-Fi 6E(802.11ax) AX210/AX1675* 2x2 [Typhoon Peak] (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
There has been some issues with networkmanager lately.
The issue has been resolved in the latest version of networkmanager: 1.46.0-2
Check if you have the version installed.
If not use your mobile hotspot and update your system.
Sadly that was the first thing I did i updated everything
This is a fresh install i forgot to mention
It’s something to do with wpa3 i figured out
I entered the wrong password
