On Dell XPS 13 – requires thunderbolt three to connect to a docking station which then connects to ethernet, bluetooth usb mouse, and hdmi for second monitor.
In the past, hdmi connection is iffy, but ethernet and mouse have always connected. This was true both with Deepin (which I switched out of recently because of other bugs I had trouble with) and now plasma.
Now, 2nd monitor works for the most part, but there is no detection by plasma of the mouse or the ethernet connection existing at all.
I just started to notice this today, but might have been happening for a few days. I have tried to restart, and logging in and out, with no changes.
Thanks!
inxi --full --admin --verbosity=7 --filter --no-host
Kernel: 5.10.13-arch1-2 x86_64 bits: 64 compiler: gcc
v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=00c1d828-42cc-4e2b-93f7-c6c15462005f rw quiet
loglevel=3 nowatchdog mem_sleep_default=deep
intel_iommu=off
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11
dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: Dell product: XPS 13 9300 v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Dell model: 077Y9N v: A00 serial: <filter>
UEFI: Dell v: 1.4.1 date: 11/23/2020
Battery:
ID-1: BAT0 charge: 39.3 Wh
condition: 45.5/51.0 Wh (89%) volts: 8.6/7.6
model: SMP DELL WN0N005 type: Li-poly serial: <filter>
status: Charging
Memory:
RAM: total: 15.22 GiB used: 2.84 GiB (18.7%)
RAM Report:
missing: Required program dmidecode not available
Info: Quad Core model: Intel Core i7-1065G7 bits: 64
type: MT MCP arch: Ice Lake family: 6
model-id: 7E (126) stepping: 5 microcode: A0
L2 cache: 8 MiB bogomips: 23968
Speed: 1270 MHz min/max: 400/3900 MHz
Core speeds (MHz): 1: 1270 2: 2095 3: 3639 4: 1580
5: 1915 6: 2030 7: 2005 8: 1319
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic
arat arch_capabilities arch_perfmon art avx avx2
avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni
ht hwp hwp_act_window hwp_epp hwp_pkg_req ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdtscp rep_good sdbg sep sha_ni
smap smep split_lock_detect ss ssbd sse sse2 sse4_1
sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes
vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities: Type: itlb_multihit
status: KVM: VMX disabled
Type: spec_store_bypass mitigation: Speculative Store
Bypass disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers
and __user pointer sanitization
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB:
conditional, RSB filling
Device-1: Intel Iris Plus Graphics G7 vendor: Dell
driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:8a52 class ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB
driver: uvcvideo bus ID: 3-9:3 chip ID: 0bda:5511
class ID: fe01 serial: <filter>
Display: x11 server: X.org 1.20.10 compositor: kwin_x11
driver: loaded: intel unloaded: fbdev,modesetting,vesa
resolution: <missing: xdpyinfo>
Message: Unable to show advanced data. Required tool
glxinfo missing.
Device-1: Intel Smart Sound Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:34c8 class ID: 0403
Sound Server: ALSA v: k5.10.13-arch1-2
Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless
Network Adapter
vendor: Bigfoot Networks driver: iwlwifi v: kernel
port: 4000 bus ID: 00:14.3 chip ID: 8086:34f0
class ID: 0280
IP v4: <filter> type: dynamic noprefixroute
scope: global broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter
type: USB driver: usb-network bus ID: 6-2.4:4
chip ID: 0bda:8153 class ID: 0a00 serial: <filter>
WAN IP: <filter>
Bluetooth:
Device-1: Intel type: USB driver: btusb v: 0.8
bus ID: 3-10:4 chip ID: 8087:0026 class ID: e001
Message: Required tool hciconfig not installed. Check
--recommends
RAID:
Message: No RAID data was found.
Local Storage: total: 953.87 GiB used: 77.45 GiB (8.1%)
SMART Message: Unable to run smartctl. Root privileges
required.
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel
model: SSDPEMKF010T8 NVMe 1024GB size: 953.87 GiB
block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 7003
temp: 33.9 C
Message: No Optical or Floppy data was found.
ID-1: / raw size: 390.62 GiB size: 383.49 GiB (98.17%)
used: 77.36 GiB (20.2%) fs: ext4 dev: /dev/nvme0n1p7
maj-min: 259:7 label: N/A
uuid: 00c1d828-42cc-4e2b-93f7-c6c15462005f
ID-2: /boot/efi raw size: 190 MiB
size: 186 MiB (97.89%) used: 91.2 MiB (49.0%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:1 label: ESP
uuid: 30DF-6832
Alert: No Swap data was found.
Unmounted:
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB
fs: <superuser required> label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 547.55 GiB
fs: bitlocker label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB
fs: ntfs label: WINRETOOLS uuid: 3830AA4330AA07C8
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 13.11 GiB
fs: ntfs label: Image uuid: F812AA9A12AA5D7E
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.3 GiB
fs: ntfs label: DELLSUPPORT uuid: BE181DA1181D59AB
USB:
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1
rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
class ID: 0900
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4
rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
class ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 12
class ID: 0900
Device-1: 3-5:2 info: Shenzhen Goodix FingerPrint
type: <vendor specific> driver: N/A interfaces: 1
rev: 2.0 speed: 12 Mb/s chip ID: 27c6:533c
class ID: ff00
Device-2: 3-9:3 info: Realtek Integrated_Webcam_HD
type: Video driver: uvcvideo interfaces: 5 rev: 2.0
speed: 480 Mb/s chip ID: 0bda:5511 class ID: fe01
serial: <filter>
Device-3: 3-10:4 info: Intel type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 6
class ID: 0900
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2
class ID: 0900
Hub-6: 5-2:2 info: Realtek Dell dock ports: 5 rev: 2.1
speed: 480 Mb/s chip ID: 0bda:5487 class ID: 0900
Hub-7: 5-2.3:3 info: Realtek Dell dock ports: 6
rev: 2.1 speed: 480 Mb/s chip ID: 0bda:5413
class ID: 0900
Device-1: 5-2.3.1:8 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: N/A interfaces: 3
rev: 2.0 speed: 12 Mb/s chip ID: 046d:c52b
class ID: 0300
Device-2: 5-2.3.4:6 info: Realtek USB Audio type: Audio
driver: N/A interfaces: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 0bda:402e class ID: 0102 serial: <filter>
Device-3: 5-2.3.5:7 info: Dell Dell dock type: HID
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 413c:b06f class ID: 0300
Device-4: 5-2.5:4 info: Dell Dell dock type: HID
chip ID: 413c:b06e class ID: 0300
Hub-8: 6-0:1 info: Full speed (or root) Hub ports: 2
class ID: 0900
Hub-9: 6-2:2 info: Realtek Dell dock ports: 4 rev: 3.1
speed: 10 Gb/s chip ID: 0bda:0487 class ID: 0900
Hub-10: 6-2.3:3 info: Realtek Dell dock ports: 4
rev: 3.1 speed: 5 Gb/s chip ID: 0bda:0413
class ID: 0900
Device-1: 6-2.4:4
info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Ethernet Network,CDC-Data driver: N/A
interfaces: 2 rev: 3.0 speed: 5 Gb/s chip ID: 0bda:8153
System Temperatures: cpu: 60.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 287 Uptime: 1d 6h 00m wakeups: 17156
Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.1 Packages: 1600 pacman: 1595 lib: 447
flatpak: 5 Shell: Bash v: 5.1.4 running in: konsole
inxi: 3.3.00
Thanks!
