The bluetooth service isn’t running. I gave you the command to enable it. Then check the status again.
I get this:
[usr@DESKTOP-USR ~]$ sudo systemctl enable bluetooth.service && sudo systemctl start --now bluetooth.service
[usr@DESKTOP-USR ~]$ sudo bluetoothctl
Waiting to connect to bluetoothd...
Did you check the status again after enabling it to make sure it’s running.
sudo systemctl status bluetooth
Yes, same result unfortunately.
○ bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: inactive (dead)
Docs: man:bluetoothd(8)
Jul 07 17:51:06 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condition check (Conditio>
Jul 07 17:51:36 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condition check (Conditio>
Jul 07 17:52:31 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condition check (Conditio>
Jul 07 18:02:01 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condition check (Conditio>
Jul 07 18:05:42 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condition check (Conditio>
Jul 07 18:07:21 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condition check (Conditio>
OMG
Please show the output of this command!
Your Ideapad has an Fn-key for turning airplane mode on / off!
Fn +
(airplane-symbol looking little different, ‘flying in left direction’)
Yes i asked that too. Airplane mode turns WiFi and Bluetooth off.
You can try the command this way but check this first. What does rfkill show?
rfkill
sudo systemctl enable --now bluetooth
Then check status
When I press this, the WiFi gets turned on and off. It doesn’t seem to have effect on the Bluetooth…
It has to be on as the bluetooth is part of the WiFi chip.
Edit: Nothing is going to work if the bluetooth isn’t turned on and the blutooth service isn’t enabled and started.
$ rfkill
ID TYPE DEVICE SOFT HARD
0 wlan ideapad_wlan unblocked unblocked
1 bluetooth ideapad_bluetooth unblocked unblocked
2 wlan phy0 unblocked unblocked
[usr@DESKTOP-USR ~]$ sudo systemctl enable --now bluetooth
[sudo] password for usr:
[usr@DESKTOP-USR ~]$ sudo systemctl status bluetooth
Jul 07 17:51:06 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condit>
Jul 07 17:51:36 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condit>
Jul 07 17:52:31 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condit>
Jul 07 18:02:01 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condit>
Jul 07 18:05:42 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condit>
Jul 07 18:07:21 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condit>
Jul 07 18:20:03 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condit>
lines 1-12/12 (END)...skipping...
Jul 07 17:51:06 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Jul 07 17:51:36 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Jul 07 17:52:31 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Jul 07 18:02:01 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Jul 07 18:05:42 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Jul 07 18:07:21 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Jul 07 18:20:03 DESKTOP-USR systemd[1]: Bluetooth service was skipped because of a failed condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
You are sure WiFi is turned on?
Pretty sure, I’m messaging you now on the WiFi
uname -r gives the active kernel.
Can you post the output here?
Did you happen to remove something?
sudo pacman -S --needed bluez bluez-utils
Sure!
5.18.9-arch1-1
try this:
sudo pacman -S linux-lts-headers linux-lts
then:
sudo reboot
It doesn’t seem like that:
warning: bluez-5.64-2 is up to date -- skipping
warning: bluez-utils-5.64-2 is up to date -- skipping
there is nothing to do
Try as @anon11595408 suggests to see if it will work on the lts kernel.
