No audio comes from Pipewire-pulse
Yesterday it was fine but not today,it is either caused by a system update or gpu-passthrough for vm.
I tried using pulseaudio instead but that didn’t work either.I tried a lot of things from the forums but still no so here i am.Help would be appreciated.
Here,somethings that maybe be important:
inxi -Fza:
  Kernel: 6.6.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
    root=UUID=34e2908e-3274-454e-98bd-c24ac5bf0068 rw rootflags=subvol=@
    nowatchdog nvme_load=YES loglevel=3 amd_iommu=on
  Desktop: Hyprland vt: 7 dm: LightDM v: 1.32.0 Distro: EndeavourOS
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop M3500QC_M3500QC
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: M3500QC v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: M3500QC.308 date: 04/27/2022
Battery:
  ID-1: BAT0 charge: 42.1 Wh (76.0%) condition: 55.4/63.0 Wh (87.9%)
    power: 19.1 W volts: 12.0 min: 12.0 model: ASUSTeK ASUS Battery type: Li-ion
    serial: N/A status: discharging cycles: 151
  Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80) stepping: 0
    microcode: 0xA50000C
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1561 high: 2199 min/max: 400/4680 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1755 2: 1756 3: 1505
    4: 2199 5: 1597 6: 1592 7: 1558 8: 1583 9: 1585 10: 1596 11: 1755 12: 1757
    13: 2192 14: 400 15: 400 16: 1756 bogomips: 105407
  Vulnerabilities:
  Type: gather_data_sampling status: Not affected
  Type: spec_rstack_overflow mitigation: safe RET, no microcode
    prctl
    sanitization
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
    driver: nvidia v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:25a2 class-ID: 0302
  Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 51.0 C
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 13d3:5458
    class-ID: fe01 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2
    compositor: Hyprland driver: X: loaded: amdgpu,nvidia unloaded: modesetting
    alternate: fbdev,nouveau,nv,vesa dri: radeonsi gpu: amdgpu display-ID: 1
  Monitor-1: eDP-1 model: Samsung 0x4161 built: 2020 res: 1920x1080 dpi: 142
    gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: max: 1920x1080 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
    inactive: device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.2.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
    16.0.6 DRM 3.54 6.6.1-zen1-1-zen) device-ID: 1002:1638 memory: 500 MiB
    unified: no
  Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: vfio-pci
    alternate: snd_hda_intel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
    gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api
  Server-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctl
  Server-2: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF-ID-1: docker0 state: down mac: <filter>
  IF-ID-2: virbr0 state: down mac: <filter>
Bluetooth:
  Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:5 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 4 state: down bt-service: disabled
  Local Storage: total: 953.87 GiB used: 183.33 GiB (19.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM001TD3JX013N
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 36.9 C
    scheme: GPT
  ID-1: / raw-size: 220.79 GiB size: 220.79 GiB (100.00%)
    used: 28.14 GiB (12.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
    maj-min: 259:7
  ID-2: /boot/efi raw-size: 103 MiB size: 101.4 MiB (98.45%)
    used: 563 KiB (0.5%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p6
    maj-min: 259:6
  ID-3: /home raw-size: 215.98 GiB size: 215.98 GiB (100.00%)
    used: 155.19 GiB (71.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
    maj-min: 259:5
  ID-4: /var/log raw-size: 220.79 GiB size: 220.79 GiB (100.00%)
    maj-min: 259:7
  System Temperatures: cpu: 52.6 C mobo: N/A gpu: amdgpu temp: 51.0 C
  Fan Speeds (rpm): cpu: 0
  Processes: 427 Uptime: 40m wakeups: 0 Memory: total: 16 GiB note: est.
  available: 15.03 GiB used: 2.63 GiB (17.5%) Init: systemd v: 255
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1549
  pm: pacman pkgs: 1545 libs: 447 tools: yay pm: snap pkgs: 4 Shell: fish
  v: 3.6.1 default: Bash v: 5.2.15 running-in: foot inxi: 3.3.31
lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
	Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
	Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
	Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
	Kernel driver in use: pcieport
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
	Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
	Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
	Subsystem: ASUSTeK Computer Inc. FCH SMBus Controller
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
	Subsystem: ASUSTeK Computer Inc. FCH LPC Bridge
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 3
	Kernel driver in use: k10temp
	Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 7
01:00.0 3D controller: NVIDIA Corporation GA107M [GeForce RTX 3050 Mobile] (rev a1)
	Subsystem: ASUSTeK Computer Inc. GA107M [GeForce RTX 3050 Mobile]
	Kernel driver in use: nvidia
	Kernel modules: nouveau, nvidia_drm, nvidia
02:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
	Subsystem: Intel Corporation Wi-Fi 6 AX200NGW
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
03:00.0 Non-Volatile memory controller: SK hynix Gold P31/BC711/PC711 NVMe Solid State Drive
	Subsystem: SK hynix Gold P31/BC711/PC711 NVMe Solid State Drive
	Kernel driver in use: nvme
	Kernel modules: nvme
04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne [Radeon Vega Series / Radeon Vega Mobile Series] (rev c4)
	Subsystem: ASUSTeK Computer Inc. Cezanne [Radeon Vega Series / Radeon Vega Mobile Series]
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
04:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
	Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
04:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
	Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
	Kernel driver in use: ccp
	Kernel modules: ccp
04:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
	Subsystem: ASUSTeK Computer Inc. Renoir/Cezanne USB 3.1
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
04:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
04:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
	Subsystem: ASUSTeK Computer Inc. ACP/ACP3X/ACP6x Audio Coprocessor
	Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh
04:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
	Subsystem: ASUSTeK Computer Inc. Family 17h/19h HD Audio Controller
	Kernel driver in use: vfio-pci
05:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
	Subsystem: ASUSTeK Computer Inc. FCH SATA Controller [AHCI mode]
	Kernel driver in use: ahci
05:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
lsmod | grep snd_hda_intel
snd_hda_intel          65536  1
snd_intel_dspcfg       40960  2 snd_hda_intel,snd_sof
snd_hda_codec         237568  2 snd_hda_codec_hdmi,snd_hda_intel
snd_hda_core          151552  3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_pcm               225280  12 snd_sof_amd_acp,snd_hda_codec_hdmi,snd_pci_acp6x,snd_hda_intel,snd_hda_codec,snd_sof,snd_compress,snd_soc_core,snd_sof_utils,snd_hda_core,snd_pci_ps,snd_pcm_dmaengine
snd                   167936  15 snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_sof,snd_timer,snd_compress,snd_soc_core,snd_pcm
systemctl --user status pipewire
pipewire.service - PipeWire Multimedia Service
     Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
     Active: active (running) since Sun 2023-11-19 11:10:14 +03; 24min ago
TriggeredBy: ● pipewire.socket
   Main PID: 237076 (pipewire)
      Tasks: 4 (limit: 18339)
     Memory: 4.6M (available: 14.7G peak: 4.8M)
        CPU: 59ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
             └─237076 /usr/bin/pipewire
Kas 19 11:10:14 semih-vivobook systemd[1181]: Started PipeWire Multimedia Service.
Kas 19 11:10:14 semih-vivobook pipewire[237076]: [0:18:11.152716693] [237076] ERROR IPAM>
Kas 19 11:10:14 semih-vivobook pipewire[237076]: [0:18:11.152741416] [237076] ERROR IPAM>
Kas 19 11:10:14 semih-vivobook pipewire[237076]: [0:18:11.152790094] [237076]  INFO Came>
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 1: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
Pavu control conf:
Renoir Radeon High Definition Audio Controler values accepted are:closed,professional sound,digital surround 5.1 (not plugged),digital surround 7.1 (not plugged),digital stereo(not plugged)
None of the above settings/values work.
Ok so problem was linux-zen for some reason.It didn’t load Family 17h/19h HD Audio controller,probably missing few modprobes.
