When I make a change in my i3 config I often do Mod+Shift-e to do a clean start of i3.
Once in a while the wallpaper is not be displayed. When I log out en log in again then the wallpaper works.
Not a very big problem, but I just wonder why this happens.
It happens when you reload the i3
config file it reloads the WM system. So, sometimes nitrogen
being a 3rd party doesn’t load or crashes. When you log out and log in everything is autoloaded as they should also with parameters set for software like nitrogen
. I’ve seen this in awesome and one two other wm’s
in the i3 config, are you calling nitrogen with exec
or exec_always
The former will start nitrogen only when you login, while the latter will start nitrogen every time you reload config.
If his using our default, I think it’s using exec
to call nitrogen
exec or exec_always does not make any difference, because I do Mod-Shift-e after a config change, which logs me out.
Even then sometimes nitrogen doesn’t show up the first time, but only after a second logout/login.
Note that this does not happen all the time. Just now and then. Seemingly randomly.
In environments with fast startup like i3 and sway, it seems it may be a timing issue.
Insertion of something like sleep 2s before the nitrogen exec may prove that (or maybe I’m crazy?).
exec --no-startup-id sleep 2 && nitrogen --restore
